Need help with supposed cracked block on a 96 ss - Chevy Impala SS Forum
post #1 of 53 (permalink) Old 02-02-2017, 09:17 AM Thread Starter
Picked up a 1996 impala ss yesterday that supposedly has a cracked block. I need some help to determine if it is really cracked or if it may be something else. The previous owner told me he had top end rebuilt and the motor has lots of new parts including opti and water pump. It cranks and runs the idiot light is flashing says low coolant and runs real rough but it doesn't smoke just really need some guidance or a good idea of what to start checking. I have another 5.7 that I pulled out of a 95 and before swapping them I want to see if it's salvageable or not. Any help would be greatly appreciated
Sent from my SAMSUNG-SM-N920A using Tapatalk
96texasss is offline
post #2 of 53 (permalink) Old 02-02-2017, 10:12 AM
.....I need some help to determine if it is really cracked or if it may be something else.
......It cranks and runs the idiot light is flashing says low coolant and runs real rough but it doesn't smoke just really need some guidance or a good idea of what to start checking. .....
Considering just the useful info, there's a lot left for you to contribute before a worthwhile response.
You surely asked, so what indications exactly did the seller give for her/m to state the block was cracked? Especially since it runs.
If internal, how does/did her/m know it's a crack and not mech. failure? If external, are/was there physical symptoms of a crack - leaking or shooting fluids, staining, visible break?
You may want to fill the AF, find a way to pull codes, and deal with the rough condition. Do you or a friend know how to tell a flattened cam, broke rocker, rod knock or any number of things potentially caused simply by seller's abuse?
That's all I got until you dig more on your own. It's gotta be better use of time and $$ to buy and study a FSM for $50 before swapping a whole motor.
post #3 of 53 (permalink) Old 02-02-2017, 10:24 AM Thread Starter
The guy told me that he had taken it to a shop and that they told him the block was cracked. I was thinking a leak down and then a compression test to see if there is any noticeable difference in the cylinders and or a loss of pressure in the cooling system. I had it on a trailer and when I pulled her off I didn't see any indications of a leak so I was thinking that unless the Crack is internal or so miniscule that it doesn't leak that it could be something different because it runs rough but it runs cranked right up no problems and for 1700 it was a steal so I'm not sure as to what to do or where to begin
post #4 of 53 (permalink) Old 02-02-2017, 10:44 AM
babywag's Avatar
Fill it up with distilled water and pressure test system.
Coolant low, no signs of leak on trailer, runs like poo...
Leans towards it dumped coolant/overheated and may now have other issues.
Guy sold it because he didn't want to deal with it, now it's your turn
Just my .02
'94 Caprice Wagon - Bilstein shocks, Hotchkis rear trailing arms & sway bars, Moog 80098/CC623 springs, AR Torq Thrust II wheels w/ 255/50/17 tires, Bonneville seats, and a LOT of new parts. Some day it'll be done...to do list, engine swap, Jegs Catback exhaust, and 24x conversion.
babywag is offline
post #5 of 53 (permalink) Old 02-02-2017, 10:48 AM Thread Starter
Yea probably lol. But I wasn't to worried I paid 10k for my daily driver in '09 so 1700 and in great shape except the motor and I have another block waiting didn't seem like a deal I could pass up
post #6 of 53 (permalink) Old 02-02-2017, 10:57 AM
The guy told me that he had taken it to a shop and that they told him the block was cracked. ....
Ok, you know pretty much nothing at this point. It could be anywhere from simple ignorance, incompetence or laziness, up to hopeful charge for teardown/replacement.
And at 3 posts total under your belt you may not realize the perhaps best feature about this forum is the vast intel archived here. My guidance is fill the AF. It might take 5 start cycles for the light to go off - don't worry. Just get all the damn air out of the system. There's search for that. Get to AZ/O'R or Advance to read codes and deal with those first. There's search for every code you can think of. Then, attend to the thousand normal maint. and upkeep expected for a 20-year old car. Hoses, wires, plugs, sensors, grounds, fuel system, filters. There's search for all that. And learn all the acronyms that can cause headaches, IAC, FPR, TPS, ECT, EGR, ICM, IC, EVAP. Yep, there's search for those as well. Along with all that, there's numerous stickies on 'rough idle/running'. Search them all.
EDIT: Your last above noted. But all insight still holds. 1,700 not bad. I'd still establish what's really the issue before swapping the motor - even if free. You'd hate to do that if it was only a giant overheating that fried a hose/wire/component causing rough running.
post #7 of 53 (permalink) Old 02-02-2017, 10:59 AM Thread Starter
What I was thinking just wanted a second opinion before I got started I go to school during the week so I don't really have the time until Saturday's to do troubleshooting unless the daily breaks down
post #8 of 53 (permalink) Old 02-02-2017, 02:40 PM
OP
any "2nd opinion" from any of us based on what you post (somewhat second hand info from PO) would be just a "guess"
As noted most auto part stores have OBD 2 code reader they loan out. You can buy them for $20 or so at places like Harbor Freight
Cracked block....not very common but sounds like PO got in over his head on mods, may have driven the motor to hard or it over heated severely which can cause head or block damage
Do a cooling system leak test (you usually can get that as a loan a tool thing) also and scan for codes and google wtf those codes mean and focus on whatever those pretain to.
go buy a $1 jug, or two, of distilled water for the coolant pressure test. No need spending $ on coolant until you FIO if coolant system, heads or block is leaking water somewhere
post #9 of 53 (permalink) Old 02-02-2017, 02:49 PM Thread Starter
Yea appreciate all the help tho the po didn't seem the type to push her to the limit but you never know these days either way she is a solid project and a steal at 1700
post #10 of 53 (permalink) Old 02-03-2017, 08:21 PM Thread Starter
Ok update just put obd2 and it's got random misfire oil looks a little milky but can't really tell in the dark gonna do a leak down on it tomorrow. How can I find The misfire?
