Best filter for synthetic oil - Chevy Impala SS Forum
 3Likes
post #1 of 13 (permalink) Old 02-16-2017, 09:23 PM Thread Starter
Dutchess B Body's Avatar
Can anyone recommend the best filter for synthetic oil?. I have read BITOG and seen oil filters cut open but everyone has a different opinion. People rave about one brand while someone else hates that same brand.
Dutchess B Body is offline
post #2 of 13 (permalink) Old 02-16-2017, 10:49 PM
A NAPA Gold or the WIX equivalent would be more than adequate.
DeuceSS likes this.
threeimpalas is offline
post #3 of 13 (permalink) Old 02-16-2017, 11:14 PM
TGO
I just use the AC Delco PF 52.
A couple of times there was a sale when you buy Mobil 1 you get a Mobil 1 filter and then I used that.
KW Baraka and 4DoorSS like this.
TGO is offline
post #4 of 13 (permalink) Old 02-17-2017, 07:02 AM
Rock Auto will have good filters on their close-out sales from time to time and you can get premium filters cheap. I picked up 10 Mobil 1 filters for the wagon for less than $2.00 each. They usually have rebranded Wix at a great price. Right now, they don't have anything that great for the LT1 cars, but it changes from day to day sometimes-
Wholesale Closeout Parts : 1995 CHEVROLET CAPRICE 5.7L V8
Old Coot is offline
post #5 of 13 (permalink) Old 02-17-2017, 07:03 AM
Any "trusted" standard brand you would use for Dino Oil.....AC Delco, Purolator, Wix, etc. Stay FARRRR away from Fram. There is a thread somewhere here that talks about filter Brands and what's good, whats not and Why.
post #6 of 13 (permalink) Old 02-17-2017, 09:52 AM
I hunt for WIX or Carquest. For the latter I forgot which is better, red or blue. But I'll have to find out again. The light says I need to do a change. A 3-gallon tranny flush too! Just in time for the weekend. Need to check the beer.
Perfect reminder. This thread delivers!
EDIT!: Nothing happening at AZ or Advance on oil, but I got Mobil Super Synthetic 5-30 and the fat WIX 51258 for $28 at OR. Then again, AZ has full synth Valvoline Dexron VI for $20 compared to the other two's $26 and $27.
post #7 of 13 (permalink) Old 02-17-2017, 10:32 AM
juniorwatson's Avatar
I think it's a good idea to stay away from the standard Fram filters, but I've read good reports about the Ultra Synthetic filter.
Couldn't find anything quickly on them to link though...
juniorwatson is online now
post #8 of 13 (permalink) Old 02-17-2017, 12:53 PM
TGO
Personally, I don't see why people even bother going so crazy over oil filters. I use AC Delco because obviously it meets or exceeds the specifications for the engine(s) the filter is being used on and whatever oil should be used with them.
I don't see any need in my mind to go above and beyond that.
When I had a Ford I used Motorcraft. When I had a Volvo I used whatever their brand was. I think it was Mahle.
If they wanna give me a free filter, then ok I'll use Mobil 1 lol
TGO is offline
post #9 of 13 (permalink) Old 02-17-2017, 01:41 PM
The GRAIL Site has this Filter Report Card in their technical Documents page....
http://grail-ss.com/GRAIL%20Website%...er%20specs.pdf
....I know I've seen other info elsewhere just not sure where I've seen it. I am surprised by the Grade AC Delco got.
BTW - Check out the GRAIL site as there are a lot of very good and well written articles up there on many topics.
post #10 of 13 (permalink) Old 02-17-2017, 07:32 PM
JimCT_9C1's Avatar
Also keep in mind your planned oil change interval. I believe filters rated for synthetic oils are designed to last for the longer interval.
Didn't think it mattered until I changed a cartridge filter for a buddy that was used with synthetic and a long interval and it was like pulling a full roll of wadded up paper towels out of the canister. You would probably never even know with a spin-on filter.
Jim
1995 Caprice 9C1
Dynomax Catback, K&N Cold Air Kit, 3.73s, Other Little Stuff ...
CT Tri-9, ECIRS, ISSCA
JimCT_9C1 is offline
