Paper Oil Filter Adapter - Lubricate on install? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 03-19-2017, 07:05 PM Thread Starter
juniorwatson's Avatar
Folks,
I'm doing the upgrade of my '98 Tahoe (5.7 Liter) oil cooler lines, similarly to what the folks have done here a bunch of times.
I never looked it up in mt B-Body book when I did this to my 9C1, but I was looking thru the FSM for the Tahoe and it stated that the paper gasket should be well lubricated upon install.
Does anyone have any thoughts on why to lubricate on install?
Thx.
juniorwatson is offline
post #2 of 3 (permalink) Old 03-20-2017, 08:48 AM
being paper gasket and having worked on many valves / rebuilding etc. the lubing is done so that the gasket will not distort because of one area of gasket swelling where the oil gets absorbed. so you want the complete gasket evenly coated .
j cat is offline
post #3 of 3 (permalink) Old 03-20-2017, 09:24 AM
Blue Wail's Avatar
Sounds like a good idea.
N
10.87 @ 121 mph (MD Int' Raceway 11/14/2016)
Dry 150 shot through MAF (.062 jet)
Junk 355, Stock Iron heads; CC502 cam
4500 ati Turbo 400 4.56
9C1 'Anteloupe' 3300 lb
(World's lightest full-frame Bcar)
Blue Wail is offline
