OBD1 scan code reader for the 1994-95 LT-1? - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 11-14-2009, 10:20 PM Thread Starter
Does anyone know of a OBD1 scan code reader for the 1994-95 LT-1?
Thanks
skill3 is offline
post #2 of 14 (permalink) Old 11-15-2009, 10:49 AM
Vendor
NO DUBS's Avatar
For just a reader/scanner check ebay. They are way cheaper then buying them at the parts store.
94 Impala SS with a decent amount of work
NO DUBS is offline
post #3 of 14 (permalink) Old 11-18-2009, 01:38 AM Thread Starter
So, what brand and model number am I looking for?
skill3 is offline
post #4 of 14 (permalink) Old 11-18-2009, 12:12 PM
Another option is to just buy a obd1 pc cable. If you have a laptop, you can read codes, clear codes, program/tune, etc.... You can find free scanning programs online, but tuning SW generally has a price (for the good ones).
http://www.pcmperformance.com/cables.html
Mike
94 Caprice Wagon, tow pack/posi, N97 wheels, CAI, IMCO turbo mufflers / resonator delete (Sold)
mike_tx is offline
post #5 of 14 (permalink) Old 11-19-2009, 07:04 AM
Carlton's Avatar
I've got this cable: http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
Works great with the provided free software (Freescan: http://www.andywhittaker.com/ECU/Fre...0/Default.aspx )
1991 Caprice Classic - 1998 LS1 Camaro - 1995 Impala SS (sold)
Netherlands
Carlton is offline
post #6 of 14 (permalink) Old 11-19-2009, 01:58 PM
Be careful - the really cheap ones are a paper clip in a plastic case. Get one that actually reads codes - not just turn your fans on. Before the crash, there were some threads on the good ones - they really do exist.
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
grandpas wagon is offline
post #7 of 14 (permalink) Old 11-20-2009, 12:52 AM Thread Starter
I really appreciate all of the replies, but can someone give me a manufacturer and model number that will work with the 94-95 LT1's?
Thanks
skill3 is offline
post #8 of 14 (permalink) Old 11-20-2009, 01:27 AM
This is a good one from a respected known company. Goes for about $150. A Google search for OBD1 scanners will provide more results.
http://www.autoxray.com/whats_new_detail.php?id=41
grandpas wagon
post #9 of 14 (permalink) Old 11-13-2016, 04:23 PM
OBD1 scan code reader for 1994
On 11/13/2016 Autoxray.com dose not exist any longer
rmont917 is offline
post #10 of 14 (permalink) Old 11-14-2016, 07:45 PM
ocala's Avatar
I have this Craftsman model. I've never had a problem reading any obd1 or obd2 code, or clearing them.
Except for my '95 Roadmaster. I still don't know why it won't read codes on the Roadmaster. All it does is turn on the fans... thankfully I could pull them from the climate control in the Roadmaster.
It has pulled codes on many other obd1 and obd2 cars without a problem. It was about $280 new though. Paid for itself many times...
ocala is offline
