ERROR CODE P0174 System Too Lean (Bank 2) - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 01-10-2010, 06:31 PM Thread Starter
my check engine lights comes on ever 2 days and goes off random and i was wondering is this error code related to o2 sensor or intake needing be clean or exhaust system needing to be hooked up to one of those machines that cleans carbon and gunk out system cause friends are giving me so many reasons keep in mind im not noticing any problems in drivng in my 96 ss
black013 is offline
post #2 of 6 (permalink) Old 01-10-2010, 06:35 PM Thread Starter
oh yea keep in mind ive replace the fuel pump twice within 3 months (Airtek) and im thinking this new one about to die on me too (dont know wats killing these fuel pumps?)
black013 is offline
post #3 of 6 (permalink) Old 01-10-2010, 07:32 PM
DiGGM95's Avatar
First, make sure the fuel psi holds good during a drive, then check for exhaust leaks before the pass. o2 sensor. Could be leaking around the back of the manifold, or even at the egr pipe. An egr valve thats not closing all the way or leaky smog check valve could also cause this, but other codes should show up if this was the case. Last, if no leaks are found, try swapping the pass. o2 sensor to the opposite side and see if the code follows (should go from p0174 to p0171). If the code changes, replace the 02 sensor.
1995 Caprice 9C1
1995 GMC Yukon
2003 **** CVPI
2009 **** CVPI
Youtube
DiGGM95 is offline
post #4 of 6 (permalink) Old 01-10-2010, 07:37 PM
wytltng's Avatar
Check for vacuum leaks.
wytltng is offline
post #5 of 6 (permalink) Old 01-10-2010, 10:09 PM Thread Starter
Gottcha so basically swap o2 sensors get error 0171 just need replace before cat
black013 is offline
post #6 of 6 (permalink) Old 01-10-2010, 10:30 PM
DiGGM95's Avatar
Just replace the passenger side front o2 sensor if swapping it to the drivers side makes the code change to p0171, this proves that the o2 that was in the pass. side is reading wrong, instead of the pass. side having a real world lean condition (reset the pcm/clear the p0174 code before the swap test). The back o2 sensors ONLY monitor catalyst efficency. If you need an 02 sensor, AC Delco/Delphi or Denso are the best for our engines.
1995 Caprice 9C1
1995 GMC Yukon
2003 **** CVPI
2009 **** CVPI
Youtube
DiGGM95 is offline
