Bad canister purge solenoid - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 02-19-2010, 07:56 AM Thread Starter
Question Bad canister purge solenoid
What happens to my car if I don't change it and where is it located. And also what kind of spark plugs do I use i go platium tip in right now are there any diffferent in proformace with acdelco plug I'm thinking about changing
96fordkiller is offline
post #2 of 4 (permalink) Old 02-19-2010, 08:06 AM
Your purge solenoid valve is located on the passenger side of the intake manifold. It will be mounted with one small bolt into the intake and have an electrical plug.
Ron
96 Impala SS, T56, CenterForce DF 4.56 gears, 383 Stroker, AI Heads
05 Dodge Ram SRT10
08 Trailblazer SS
79 Chevy Luv 4WD
Oklahoma is offline
post #3 of 4 (permalink) Old 02-19-2010, 09:50 AM
Bad Imp's Avatar
Is the solenoid valve bad?
If you have a stock setup just go the AC Delco plugs and you will be just fine.
Las Vegas Impala SS Club - SSincitySS.com
1996 Impala SS, Powerdyne Supercharger 6 psi, 3.73s, Snow Performance water/meth injection, Borla catback, F-Body MAF, Grotyohann long tube headers, Magnaflow cats, Hotchkis springs/front & rear sway bars, Bilstein shocks, Vigilante 3000 stall TC, Wilwood brakes, 20in Budnik Fontana's, and a couple of polished items
Bad Imp is offline
post #4 of 4 (permalink) Old 02-19-2010, 11:12 AM
HuSSker's Avatar
That bolt/bracket o nthe manifold are on the '96 only. On 94-95's, it is on the home plate braket, in the in the same area as the '96, around the middle of the passenger side of the manifold. There is a narrow metal tab you can pry up to allow the valve to be slid off of th ehome plate support bracket.
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
HuSSker is offline
