Check Codes on OBD 1 ? - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 05-08-2010, 08:25 PM Thread Starter
chevyguy's Avatar
How can I check for codes in my 1995 Impala ? What tools if any will I need ? I remember some sort of jumper wire to the OBD on my 1982 Camaro, does the same apply here ? If so, which ports on the OBD do the wires get jumped to ?
CALI-SS ,1995 BBB Murdered out, Powder Coated C5 Corvette Wheels, Cross Drilled / Slotted rotors F & R, Brake bolt mod, LS2 swap, psi converion harness, brp hotrods longtube ceramic coated headers, Hummer H3 oil pan, CAT Delete, 2.5 X-Pipe Exhaust, Hooker Aero Chamber Mufflers, 160 Stat, Pro Built 4L65, and most important of all Tuned by TAD !!! More to come....
chevyguy is offline
post #2 of 2 (permalink) Old 05-08-2010, 10:14 PM
oldkoot's Avatar
Can't use the paper clip jumper, you'll need to scan for codes, a lap top with ADL cable or go to Autozone and they'll scan for codes for free.
94 Caprice Wgn,DCM,C5 corvette brakes,impala SS 17" rims,kumho tires,flowtech headers,pcm for less,ram-it,pioneer sound sys,hooker aero chambers,gauge pod,b&m floor shifter, full tint,Eibach springs,sway bars,3.73 yukon gears,eaton posi,14.2@97mph without a tail wind.
oldkoot is offline
