Rear main seal replacement advice - Chevy Impala SS Forum
post #1 of 24 (permalink) Old 07-08-2010, 01:45 AM Thread Starter
BABYBLUE9C1's Avatar
well time has come to change this seal, so was hoping you guys can offer some helpful tips
so far i know i can drop the tranny and go in from there,
so any advice guys, im all ears
thanks
So Cal INC
1996 Caprice 9c1
5-15-1996
R.I.P. David Fornwalt...burnin' rubber from up above
BABYBLUE9C1 is offline
post #2 of 24 (permalink) Old 07-08-2010, 02:26 AM
94MI9C1's Avatar
Haven't done one yet, but did look into it sometime ago. Pretty straight forward, the seal housing has pry tabs on it, so you can pry it out. When installing tap evenly around the edge, make sure you lube up the inner portion that mates to the crank, so it will slide on easier. This pic may help
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #3 of 24 (permalink) Old 07-08-2010, 02:58 AM
Dustan's Avatar
Send a message via AIM to Dustan
That couldnt of been done any better Mike.
1996 Impala SS DGGM-Blueprinted and balanced 355, forged wiseco's, Level II heads, LE cam, U2-55ed, budget headers, 2500 stall, built 4L60E,CAI,PCMforLessed, Sprint springs, Walbro 255
1996 Impala SS DGGM (moms)-chrome stockers, flows, charcoal carpet
2006 Suzuki GSXR 750
Impala SS Owners Association of Hawaii (ISSOAH)
Originally Posted by Cracka Ass Crackuh
"Yea. You're wearing my underwear backwards. SO the hersey highway is on the front with easy access to the rear"
Dustan is offline
post #4 of 24 (permalink) Old 07-08-2010, 11:51 AM
a tool like this http://www.myaston.com/k/?view=item&...taller+J+35621
makes the job VERY easy. I did not use the KM one, IIRC it was a "matco" one i borrowed from a friend but works the same. bolts to back of crank and you just screw in the center bolt/handle on tool to press it in.
As mike said you can tap it in evenly without a tool but if you can find a tool cheap/free than use it.
Grease inner lip of seal before install. My $02 is go with the 'rubber" FelPro (not teflon) rear main seal.
post #5 of 24 (permalink) Old 07-08-2010, 02:10 PM
HYWAY KOP's Avatar
Arrow
BALLS,....Thanks again for the info on this. In a few weeks I'll be installing my YANK and will change the rear main at the same time.
FRANK
HYWAY KOP is offline
post #6 of 24 (permalink) Old 07-08-2010, 03:49 PM
I used the felpro rubber one as well. So far no leaks. As Roger said, use the tool if you can borrow one. If not, I used a small piece of wood to tap mine in. It is only a 3 minute job --- once you get the tranny out!
Ron
96 Impala SS, T56, CenterForce DF 4.56 gears, 383 Stroker, AI Heads
05 Dodge Ram SRT10
08 Trailblazer SS
79 Chevy Luv 4WD
Oklahoma is offline
post #7 of 24 (permalink) Old 07-08-2010, 05:41 PM Thread Starter
lol thanks guys, if i can i'll see about that tool, but this tranny drop is gonna blow!! more then likely i'll be doing this in my driveway(hoping not the street) and if i'm lucky my bro can give me a hand, since hes dropped his before
So Cal INC
1996 Caprice 9c1
5-15-1996
post #8 of 24 (permalink) Old 07-08-2010, 06:13 PM
you will be glad if you bought this...
http://www.harborfreightusa.com/usa/...o?itemid=39178
post #9 of 24 (permalink) Old 07-08-2010, 06:22 PM Thread Starter
wow 80 bucks is not a bad investment, but its also not in the budget right now, unless there is a great sell out here, i think i missed the 4th sale
So Cal INC
1996 Caprice 9c1
5-15-1996
post #10 of 24 (permalink) Old 07-08-2010, 07:24 PM
when I got mine it was $50....floor jack balance act is the "cheap" option
