hard to start, car hesitates and acts like it wants to cut off when I press the gas - Chevy Impala SS Forum
post #1 of 21 (permalink) Old 08-03-2010, 06:22 PM Thread Starter
BYB_CUZ's Avatar
95 chevy caprice stock.
I was thinking it was the maf, but I am getting no codes.
09 G8 GT, lets just say modded
95 b4u- basically sold sadly
2009 jeep cherokee- sold
2014 grand cherokee
BYB_CUZ is offline
post #2 of 21 (permalink) Old 08-03-2010, 06:24 PM
Have you checked fuel pressure? Should be 40 psi with key on and stay there after key is turned off.
2TFun is offline
post #3 of 21 (permalink) Old 08-03-2010, 06:29 PM Thread Starter
BYB_CUZ's Avatar
I will go check.
2014 grand cherokee
BYB_CUZ is offline
post #4 of 21 (permalink) Old 08-03-2010, 06:37 PM Thread Starter
BYB_CUZ's Avatar
i think it may be a vacuum leak, I heard a sucking noise while driving, but will a vacuum leak cause a hard start?
2014 grand cherokee
BYB_CUZ is offline
post #5 of 21 (permalink) Old 08-03-2010, 07:06 PM
Toms9C1's Avatar
Is everything secure from the MAF to the TB? A leak in that area could cause it to act like that.
Tom
ISSCA Member #2540
95 B4U: LT4 LE Cam 1.6 RR Eibachs 17" SS Whls K&N XPypes Mech fan delete+Gary's wiring harness RM Lthr seats Imp SS Rear Disc Eaton Posi Motive 3:73's Moser Axles Stainless brake lines NEW 4L60E/Dacco 2000
94 9C1: Eaton Posi 3:73's XPypes Stainless Brake lines
95 L99 DCM: SS Clone Vogtland springs Monroe SS shocks XPypes Front end overhaul w/Alum bushings
96 RMW Woody Black / Red guts
96 RMS
http://badass-of-ne.forumotion.com/forum.htm
Toms9C1 is offline
post #6 of 21 (permalink) Old 08-03-2010, 07:08 PM Thread Starter
BYB_CUZ's Avatar
Well i checked my vacuum lines and found this, i just got the car out of the shop and i told them the lines were broken right there and needed to be replaced and this is what i found. Where can i get new vacuum lines and what is the name of the connector that should be right here. Can anyone tell me what they were trying to accomplish by doing this, and can where do the vacuum lines run and i will fix it myself.
2014 grand cherokee
BYB_CUZ is offline
post #7 of 21 (permalink) Old 08-03-2010, 07:21 PM Thread Starter
BYB_CUZ's Avatar
this is the passenger side of the intake.
2014 grand cherokee
BYB_CUZ is offline
post #8 of 21 (permalink) Old 08-03-2010, 09:24 PM
95BRMW's Avatar
I think that goes to the EVAP solenoid. They probably disconnected it and jumped it to prevent a CEL.
1996 DCM SS 216k
1996 Black RMW 158k
1995 DCM Roadmaster Wagon 118K
1992 Olds CC 5.3l LS swap 181k
1994 Fleetwood 160k
1975 Impala Coupe
95BRMW is offline
post #9 of 21 (permalink) Old 08-03-2010, 09:30 PM Thread Starter
BYB_CUZ's Avatar
will this cause the problems I am having. I don't want to use shortcuts, is rather just replace the solenoid and vacuum lines. I'm going to get this sorted out this weekends.
2014 grand cherokee
BYB_CUZ is offline
post #10 of 21 (permalink) Old 08-03-2010, 09:43 PM
95BRMW's Avatar
It depends. On my caprice the elbow going from the throttle body to the pipe that then goes into the solenoid that this plugs into was rotted out and cracked badly. I can't get a replacement, thank you GM for discontinuing that part! I drove it for a while with it unplugged and capped the port on the throttle body, and aside from the CEL it ran fine. Is the solenoid still there?
1996 DCM SS 216k
1996 Black RMW 158k
1994 Fleetwood 160k
1975 Impala Coupe
95BRMW is offline
