Power Steering Pump Pulley, Help! - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 10-16-2010, 06:38 PM Thread Starter
BareProductions's Avatar
Send a message via AIM to BareProductions
I did some searching...but I don't want to mess up my pulley.
Currently doing a power steering pump change on the 9C1. I've got the lines off, pump out, etc...but I'm having trouble getting the pulley off.
How exactly is the pulley held on the pump shaft? It looks like the shaft is threaded (with an allen head) and the pulley screws on? I saw that some people used a puller...but I don't understand how that works if its threaded on.
I've got the thing soaking in PB blaster right now...will it work to put a big allen wrench in the shaft and tap on it with a hammer? If this is the way to go is it back threaded or regular?
95 Caprice Wagon: All the basic mods, Tri-Y headers, SpinTech Exhaust, 52MM TB, Bryan H Tune, Rustic control arms, AirLift Bags.
95 9C1: LE218/224 .571/.566, "561" alum heads, 1.6 RR, beehives, 54MM TB, ported intake, 2.5 catback, Hooker Aero Chambers
73 Nova: Yellow hole where I throw the rest of my $$$
83 Wife: Stock
BareProductions is offline
post #2 of 8 (permalink) Old 10-16-2010, 06:50 PM
Mean SS's Avatar
Send a message via AIM to Mean SS
it's not threaded on you need to use a puller
Mean SS is offline
post #3 of 8 (permalink) Old 10-16-2010, 06:51 PM Thread Starter
So it's just press fit on? I didn't see a nut on the end of it? Any idea why the shaft is allen threaded?
83 Wife: Stock
post #4 of 8 (permalink) Old 10-16-2010, 06:54 PM
Mean SS's Avatar
you use the threads for installing, Do you have the special puller & installer ?
Mean SS is offline
post #5 of 8 (permalink) Old 10-16-2010, 07:08 PM Thread Starter
I dont have a special tool...i read on here it can be rented from auto zone or other parts stores?
So the tool is used for installing too? I dont see much exposed thread on there right now..
Thanks for your help!
83 Wife: Stock
post #6 of 8 (permalink) Old 10-16-2010, 07:11 PM
Mean SS's Avatar
yes, different parts of the puller set are used for the install
http://www.stu-offroad.com/steering/...pspulley-1.htm
Mean SS is offline
post #7 of 8 (permalink) Old 10-16-2010, 07:13 PM
nhgonzo's Avatar
This is what it looks like.
Gonzo
Gz Custom
92 WWW? ,All Shaved WOODY,All LEDs,
96 RMW Limited stock daily driver
95 WWW stock
http://www.cardomain.com/ride/3299559
http://www.youtube.com/nhgonzo Wagon on
LEDz
nhgonzo is offline
post #8 of 8 (permalink) Old 10-16-2010, 07:39 PM Thread Starter
Ah ok that makes sense.
Anyone know if advanced auto rents this? ive got an advanced closer than autozone...ill check their site.
Thanks!
83 Wife: Stock
