Replace PCV valve? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 03-27-2011, 05:14 PM Thread Starter
Replace PCV valve?
Group,
Checked past threads without success, and looked at Qualo's SS Book, but still unsure where exactly PCV valve and housing located. Qualo's says on driver side of block in middle, essentially. I have found something that looks like it goes into the top of the block at about that location, with something that looks like a sparkplug wire connector coming off of it and heading in about a 1/4 in. tubing toward the front of the engine. Is this it? Also when replacing do you just pull the "cap" off and then somehow unscrew it? Also, assuming I got the right pcv from Auto Zone, it has a hose connection on one end, and a non-threaded cylinder on the other one. So I assume it sits in somekind of housing.
Thanks- 72k all stock 350
CruiserBill
cruiserbill is offline
post #2 of 4 (permalink) Old 03-27-2011, 05:22 PM
Does it look like this:
http://shbox.com/1/pcv.jpg
and the hoses look like:
http://shbox.com/1/pcv_pipe.jpg
The PCV valve just pulls out of the rubber grommet in the intake manifold. Easy-peasy.
Terry
2 1995 9C1s
30U Huet Silver Metallic built 5/26/95
36U Bonnat Silver Metallic built 7/19/95
1 1995 1A2
2001 Camaro B4C SOB -- one of 288
2008 Z06 Jetstream Blue built 10/11/07
Terry #585 is offline
post #3 of 4 (permalink) Old 03-27-2011, 05:22 PM
EvilCaprice's Avatar
It sits in the intake right next to the driver side manifold.
95 9C1
EvilCaprice is offline
post #4 of 4 (permalink) Old 03-27-2011, 06:20 PM Thread Starter
Perfect Answer
Group
a picture is worth a thousand words. Not quite, but real close on both pictures. The guy from Knects, located something on the back of the valve cover on the passenger side, that looked like it was going to be it. But, glad you guys responded back in a hurry, as the auto stores looked more reasonable (old school looking) than the newer version.
Thanks for the great help.
Cruiser Bill
