code P1371 along with 4 more... - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 05-09-2011, 04:24 PM Thread Starter
Forbes's Avatar
i have this code on my car along with like 4 others.... help me i have to do emissions!!! do i need a new optispark!???!?
P1441:
P0137:
P0153:
P0161:
P1371:
http://www.firebirdnation.com/forums...rebird-formula
P1371 is telling you the PCM can not find the low resolution pulse signal. When this happens, the PCM can not time the ignition or the fuel injection, so it shuts down the fuel system.If the engine is running, P1371 is a "stored" code. It is not active, so the PCM is still running the fuel system. If this is the case, clear the code (pull the "PCM BAT" fuse for 30 seconds), and see how often it comes back. If it comes back frequently, or sets when the engine stalls, its an indication that the cam position sensor in the distributor is failing, or there is a problem with the wire harness or connector. If your engine isn't starting at all, it's an "active" code, and could be a failed sensor or damaged harness/connector.
'96 SS 126K
Forbes is offline
post #2 of 10 (permalink) Old 05-09-2011, 09:42 PM
P1371 is almost always an Opti issue.
2005 Pontiac GTO
cletus284 is offline
post #3 of 10 (permalink) Old 05-09-2011, 11:22 PM
Gregg-O's Avatar
Myself, I would get a new Opti harness first...way cheaper & easier, but that's just me. If it will run, reach down and wiggle the harness and see what happen's.
Gregg-O is offline
post #4 of 10 (permalink) Old 05-10-2011, 06:09 AM Thread Starter
Forbes's Avatar
yeah the car runs fine but i feel a big power loss and bad throttle response.
'96 SS 126K
Forbes is offline
post #5 of 10 (permalink) Old 05-24-2011, 07:42 PM Thread Starter
Forbes's Avatar
i removed the negative battery terminal to clear the codes, then wiggled the opti harness and tried to start the car and now it won't start...
'96 SS 126K
Forbes is offline
post #6 of 10 (permalink) Old 05-24-2011, 10:22 PM
Rocko350's Avatar
Then that confirms the bad connection with the opti harness. I would renew the opti harness and the vacuum harness to start (no pun intended).
Chris
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
Rocko350 is offline
post #7 of 10 (permalink) Old 05-24-2011, 10:32 PM Thread Starter
Forbes's Avatar
Chris
this good enough for a replacement?
http://www.eficonnection.com/eficonn...spx?ItemId=841
'96 SS 126K
Forbes is offline
post #8 of 10 (permalink) Old 05-24-2011, 10:38 PM
94MI9C1's Avatar
Yes it is, sounds like I knew what I was talking about huh LOL. Just kidding man. Offer is still open to borrow the opti that I have to test it out with. Also read over all of the p code descriptions and diagnostic help that I sent you. It will help you more than you know
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #9 of 10 (permalink) Old 05-24-2011, 10:52 PM Thread Starter
Forbes's Avatar
my buddy thinks it's fuel related, either my fuel pump **** on me or it's my fuel pressure? i had a fuel problem before like this but it was a problem with my pump not priming and it's still priming fine.
'96 SS 126K
Forbes is offline
post #10 of 10 (permalink) Old 05-25-2011, 04:17 PM Thread Starter
Forbes's Avatar
tried to start her up this morning, first attempt it died right after start. second time it started right up perfectly fine, let it run for about 5-10 minutes shut it off and started it back up fine. also my vent hose for my opti that sticks in my intake has no suction at all.
i'm getting suction from the line with the filter on it going to my intake manifold on the side perfect.
but not the one with the blue elbow, no suction at all.
'96 SS 126K
Forbes is offline
