Awww Hell, I have a leak.... - Chevy Impala SS Forum
post #1 of 58 (permalink) Old 10-19-2011, 09:23 AM Thread Starter
Signature Section Moderator & CrossFire Club Ambassador of Kwan
Cracka Ass Crackuh's Avatar
And yes, it's on the car....
Looks like I'm leaving small puddles of oil which appears to be coming from behind the crank pulley....
Please tell me this isn't going to be THAT expensive to fix
Cracka Ass Crackuh is offline
post #2 of 58 (permalink) Old 10-19-2011, 09:25 AM
thebigbadWOLF's Avatar
how about some helpfull information like
year
motor
type
asl
do you like long walks on the beach...?
Cali-SS
thebigbadWOLF is offline
post #3 of 58 (permalink) Old 10-19-2011, 09:40 AM
juniorwatson's Avatar
Is it dripping down the front of the timing chain cover?
Is it as simple as the hub seal?
Clear Image Tri-Ys & Hi-Flow cats to CIA 2.5" X-Pipe & Spintech Mufflers, Mike Harris 4L60E, Vigilante 3,400 RPM Converter, MOOG FT end, Del-A-Lum bushings in new MOOG CTRL Arms, Eibach FT Springs, New Stock rears. Hotchkis Sway Bars & End Links, RAISS, Dynoshaft, CIA Driveshaft Loop, BMR Trailing Arms, Braided Brake Hoses, Taylor Spiro-Pro Wires, AutoMeter 2-5/8" Water Temp & Oil PSI Gauges, Impala Console. ATE Blue Brake Fluid. Skip White distributor. Newly Installed 20's on 1/1/2017
juniorwatson is offline
post #4 of 58 (permalink) Old 10-19-2011, 09:47 AM
TheImpalaMan's Avatar
Again, what year is your car?
If it's got the optispark, it could be one of 3 seals on the timing chain cover.
Water Pump drive seal
OptiSpark seal
Harmonic Balance Hub seal
Hopefully it is either the water pump drive or the optispark seal. They are the easiest to change of the 3.
-TheImpalaMan
Black 1996 Impala SS Modified. 205k Miles & Still Rockin Hard!
TheImpalaMan is offline
post #5 of 58 (permalink) Old 10-19-2011, 09:51 AM Thread Starter
D'oh! Such a n00wb mistake....
95 Caprice Wagon
Marblehead silver
LT1
162,000 miles
Just had the opti done 6 months ago, had the water pump done last week....
29/m/Tx
No, not a big fan of long walks on the beach.... mostly because I'm walking to the next gas station....
post #6 of 58 (permalink) Old 10-19-2011, 09:56 AM
Super Moderator
Synaptic's Avatar
Dont you do anything yourself crackah?
Synaptic is offline
post #7 of 58 (permalink) Old 10-19-2011, 10:02 AM
Moby Dick's Avatar
Send a message via AIM to Moby Dick Send a message via Yahoo to Moby Dick
95 Caprice Wagon
Marblehead silver
LT1
162,000 miles
29/m/Tx
Probably the seal for the WP drive since you just replaced the WP recently. Easy enough to pinch.
Eric Seaman
1994 Caprice Wagon "Moby Dick"
1996 Impala SS 383 11.604@117 CC503 with 3.73's.
1.52 60' on drag radials
"Fastest NA 383 3.73 equipped car on the board"
ISSCA Member #2517
Moby Dick is offline
post #8 of 58 (permalink) Old 10-19-2011, 10:07 AM
+1 @ wp
Cali-SS
post #9 of 58 (permalink) Old 10-19-2011, 10:08 AM
Banned
I thought you did your own auto work or at least had someone help you.
I'm certain that your opti seal is shot, if not also the water pump seal. Not just because it is easily apparent but because my original opti died from similar causes. If memory serves me right your seal is going to eventually explode shorting out your optical disks. This will sound like a big thud, the car will die, and you will be stranded.
LT Scholz is offline
post #10 of 58 (permalink) Old 10-19-2011, 10:09 AM
Don't forget to do the 2 O-rings on the WP drive shaft coupler as well if/when you do the shaft seal.
