PCV 90 degree elbow - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 02-17-2012, 08:36 AM Thread Starter
PCV 90 degree elbow
OK, so I've known for a long time that GM only makes the 'PCV pipe', part 12556257, complete and doesn't make the often deteriorating rubber elbow piece that connects the steel pipe to the PCV valve as a separate part. GD BASTARDS! And also, if anyone cares to know, the retail price is now (gasp) $45! Just three years ago you could get these for around $12-15. so here's the question - has anyone used one of Dorman/Motormite/Help PCV 90 degree elbows? I've seen some that look like they may be the right diameter. Does hose diameter matter in terms of flow of vacuum to the PCV?
Thanks for any help.
90 Mercury Grand Marquis, stock
Alchemist is offline
post #2 of 10 (permalink) Old 02-17-2012, 08:46 AM
95BRMW's Avatar
On both of my 96's I have used a delco spark plug boot (right angle one) and clamped it on the PCV valve. Been on one car for 10k and still going strong.
1996 DCM SS 216k
1996 Black RMW 158k
1995 DCM Roadmaster Wagon 118K
1992 Olds CC 5.3l LS swap 181k
1994 Fleetwood 160k
1975 Impala Coupe
95BRMW is offline
post #3 of 10 (permalink) Old 02-17-2012, 09:09 AM
Moderator
Goldmaster's Avatar
I can't remember what I paid, but Mike 94MSP9C1 got me the whole PCV tube elbow and all through Hamilton Chevy for a good price. Nowhere near $45 last year when I bought it. Check with him, he might be able to get one reasonably. I think it was under $20...
Goldmaster is offline
post #4 of 10 (permalink) Old 02-17-2012, 09:31 AM Thread Starter
Yeah, $45 is full retail. You can get one from Jason at Sam Taylor Buick for about $30. That's our ImpalaSS club discount. But hell, even $30 is way out of line...
post #5 of 10 (permalink) Old 02-17-2012, 12:23 PM
CoupeDTS's Avatar
why not just get a pcv valve for the older small block chevys that have a right angle at top and go straight into that
Known for slammin' Cadillac Doors!
1996 - Fleetwood Brougham Black on Black V4P
1983 - Coupe Deville - Street Custom Show Lowrider
1970 - Calais 4dr HT
CoupeDTS is offline
post #6 of 10 (permalink) Old 02-20-2012, 06:21 PM
usedtobeafordguy's Avatar
When I changed mine, I brought my elbow with to Napa and was able to make a similar elbow fit with some trimming. I believe you could also get an extra of the hose on the opposite end (connects to front of intake) and cut that to fit.
http://www.rmsautoparts.com/proddeta...12551389&cat=7
95 Caprice wagon DCM
ISSCA # 2424
usedtobeafordguy is offline
post #7 of 10 (permalink) Old 02-23-2012, 05:34 AM
I picked up an emission hose from advance auto, it was four dollars. I'm at work & don't have the part number with me, but it's 3/8" hose & has 2 90 degree bends in it. I just cut it to size and it fit right on. I've done this with 3 of my cars, no problems.
1995 Roadmaster Wagon
1972 Ford LGT 100
kiddpitt is offline
post #8 of 10 (permalink) Old 02-23-2012, 07:56 AM
EvilCaprice's Avatar
Can you replace the entire line, metal and all, with a regular vacuum hose? I made one fit the other day, but not sure if im going to use it or not.
95 9C1
EvilCaprice is offline
post #9 of 10 (permalink) Old 02-23-2012, 01:01 PM
Kiddpitt is right.
I used a hose that would fit the Pcv valve. A couple of bucks, Cut to fit, done.
About 40 K on mine.
Brian F
96 DCM SS (aka: The Money Pit)
09 G8GT LSX powered (MDLFCRIS)
I like Racing because football, baseball, bowling, and golf only require ONE BALL!
A different way of thinking:
http://www.gwca.org/
http://www.adoptuskids.org/
Fast4drSS is offline
post #10 of 10 (permalink) Old 02-23-2012, 05:21 PM
alwyswntd1's Avatar
i did this same thing due to not finding this elbow used a spark boot wire and works well.
oops sorry i did this for the emission side going into the throttlebody.i actually bought one of the stealership due to leak but it was like 18 bucks.let me know ill try and see if i can get one for you just pay for part and shipping.
alwyswntd1 is offline
