Shuts off - then will restart. - Page 2 - Chevy Impala SS Forum
post #11 of 17 (permalink) Old 09-10-2012, 11:13 AM
I had the same problem and just recently found out what it was. If you say your ICM is fairly new then try and check ignition coil itself...got mines running fine now
Mike Swagg2134 is offline
post #12 of 17 (permalink) Old 09-28-2012, 08:37 AM Thread Starter
VF1000R's Avatar
3 weeks later and the problem has not re-surfaced and I have done nothing. What a PIA this intermittent stuff is.
95 Impala , 96 Motor/PCM, Ported/Polished Heads - 2.02's / 1.6's, Comp XFI 468 cam, Mike Harris FL Headers, 3.0" Duals, 3.73's with Auburn Posi, CAI and 3.5" MAF, BH Tune, 150 Shot, Custom Performance Tranny with a Vigilante 3100 TC, Dual Snorkel Glass Hood and Front Bumper, DGGM. 2009 Pontiac G8GT
VF1000R is offline
post #13 of 17 (permalink) Old 09-28-2012, 09:07 AM
My similar problem turned out to be a wire to the icm that was broken inside the insulation. Perhaps the "wiggle" test might reveal this. Check for worn/damaged connectors as well.
post #14 of 17 (permalink) Old 09-28-2012, 01:19 PM
Gregg-O's Avatar
I'll second 1slow96's advise....if there was one place GM cut corners on, it is the wiring in these car's.
Gregg-O is offline
post #15 of 17 (permalink) Old 01-07-2013, 11:06 PM
Even though this thread is from a few months back, I want to add that my car has just started doing this today. The wiggle test indicates the connection to the ICM, as when I barely tug on it, the car shuts off like the key was turned off. So +1 for the wiggle test.
96 9c1 Caprice (Former Ada co. (Boise Idaho) Sheriff's Office)
Afterburner headers, 2.5" catback w/Flowmaster 50's, egr/air/evap system gone, homemade CAI, TB bypass, 160 t-stat, meziere ewp, pcmforless tune, UMI rear UCA/LCA, moog 7268 front springs, energy suspension bushings, 'The Jetsons' roof antenna, Z28 cluster, driveway paint job.
Capn America is offline
post #16 of 17 (permalink) Old 01-09-2013, 06:04 PM
impalassdude's Avatar
Send a message via AIM to impalassdude
it could still be fuel related..you suggested it would run ruff before it shuts off not always..i would still check your fuel pressure if it does it again.the wiring harness in the tank is a gremlin for just shutting off. keep us posted.
http://www.youtube.com/watch?v=GRqsOvpSxA4
President of SoFASST.com
05-06 1st place 94 class nationals
05 3rd place sound off
06 3rd place autocross
also as seen on the ITT commercial
95 caprice wagon impala clone
impalassdude is offline
post #17 of 17 (permalink) Old 01-09-2013, 06:55 PM
jking1118's Avatar
Dave, didn't you get this figured out? It was a loose ground, right? Or am I thinking of another random failure you had at Nationals?
Jonathan
jking1118 is offline
