Drain Plug and Headlight Problems.... - Page 2 - Chevy Impala SS Forum
post #11 of 12 (permalink) Old 11-27-2012, 02:49 PM
Mr pogo's Avatar
Originally Posted by larryfs View Post
The dealer says there are 2 possible drain plugs.
metric and SAE .
So I ordered both.
your dealer parts guy is incompetent.
PLUG. Engine Oil Pan Drain.
PLUG,OIL PAN DRN(M12X1.75X25)(W/SEAL)(EXC MAGNET). Required: 01
For: B 4.3W(L99) (1996-1996) (1996 - 1996).
Ive always heard good words about the fumoto's but would worry it'd get knocked off on a lowered car.
at least with the drain valves they made 15 yrs ago.
Mr pogo is offline
post #12 of 12 (permalink) Old 11-27-2012, 02:51 PM
Yeah, that dealer's a retard. This is why I hate dealers, and even generic autoparts stores!
The F107N's nipple does hang down a bit below the frame, I noticed that when I installed it; however, an F107 should clear all obstacles (at least the frame would hit before it does).
1996 Caprice Classic: LT1, B4U, DCM/ruby cloth; stock except for side trim removed
2009 Pontiac G8 GT: maverick silver/onyx cloth; mods: Solo Mach catback + resonators + HFCs, AEM short ram, Livernois ECM/TCM tunes
Turbo301 is offline
