Drain Plug and Headlight Problems.... - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 11-20-2012, 01:06 AM Thread Starter
So the other day, I went to go change my oil as it has been WAY too long since It has been done. Upon inspection, the head of my drain plug appeared to be stripped. It used a 9/16ths socket...however, all the replacement plugs I could find are half inch...will these fit without leaking?
The other bit I have is this...before I bought my Caprice Classic it was backed into by someone in a Subaru (the one with the tire on the tailgate). This dented the hood and somehow destroyed the assembly that holds in the headlight...does anyone know where I might be able to find this part and how much it would cost?
thanks,
Gmpar
Gmpar is offline
post #2 of 12 (permalink) Old 11-20-2012, 01:10 AM
4x4high's Avatar
The drain plug doesn't matter what size socket fits to remove it only that it is the proper thread for the oil pan. To answer your question, Yes it will seal assuming you have a sealing washer under the head of the drain plug before installing it. I persoanlly like the sealing washers that are metal with the internal rubber as they seam to last alot longer than the plastic or copper sealing washers.
4x4high is offline
post #3 of 12 (permalink) Old 11-20-2012, 01:18 AM Thread Starter
Oh, ok...yeah It's got a rubber piece on it...hope it works...
Gmpar is offline
post #4 of 12 (permalink) Old 11-20-2012, 02:20 AM
Mr pogo's Avatar
original drain plugs are metric thread and 15mm wrench size iirc
Mr pogo is offline
post #5 of 12 (permalink) Old 11-20-2012, 06:59 AM
Best bet on the headlight assembly is a salvage unit. Go to the for sale section here, or your local salvage yard.
2005 Pontiac GTO
cletus284 is offline
post #6 of 12 (permalink) Old 11-21-2012, 02:56 AM
Re headlights, what assembly is broken, the plastic one or the steel one where headlights and radiator are assembled? If plastic one suppose you should either buy new headlight, either go to jankyard and buy a headlight (not sure if they will sell you assebly separately fm headlight).
fernando is offline
post #7 of 12 (permalink) Old 11-21-2012, 06:37 AM
The Fooser Guy's Avatar
Wow. For a minute I thought you drained all the OEM blinker fluid out of your headlights!
That stuff is almost IMPOSSIBLE to find. A few years back Kale Auto had some:
http://kalecoauto.com/index.php?main...products_id=22
The Fooser Guy
The Fooser Guy is offline
post #8 of 12 (permalink) Old 11-24-2012, 09:00 PM
The dealer says there are 2 possible drain plugs.
metric and SAE .
So I ordered both.
larryfs is offline
post #9 of 12 (permalink) Old 11-27-2012, 12:30 PM
Replace the drain plug with a Fumoto oil drain valve (F107, or F107N): they make oil changes a breeze (filter notwithstanding LOL) and are a very good quality product.
1996 Caprice Classic: LT1, B4U, DCM/ruby cloth; stock except for side trim removed
2009 Pontiac G8 GT: maverick silver/onyx cloth; mods: Solo Mach catback + resonators + HFCs, AEM short ram, Livernois ECM/TCM tunes
Turbo301 is offline
post #10 of 12 (permalink) Old 11-27-2012, 02:03 PM
I had one of the Fumoto drain valves years ago,and they're pretty slick. Especially if the threads in the pan are "going away". Because, one can install the valve with JBweld if necessary.
