Steering Wheel locks and Engine shut off - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 11-20-2012, 11:27 PM Thread Starter
Hey,
I'm having a problem with my 95 Impala SS 5.7 L. I was driving 2 days ago and out of no where my car starts lowering speed, steering wheel locks up to where i can't turn not even a little, the check gauge light comes on and then the low oil light comes on and the car wouldn't move. So i turned the car off then back on and it started and went back to normal after driving it a bit more it happened again, turned it off then on again and it ran then again it happened. I checked the oil and it was full ...
This happened once and found out my belt ripped up causing the steering wheel to lock up and not run.
I took it to a mechanic and they tried reading codes and nothing showed up there was NO check engine light. Does anyone have an idea of what might be the problem?
killacity17 is offline
post #2 of 8 (permalink) Old 11-20-2012, 11:38 PM
Gregg-O's Avatar
Have them check fuel pressure.
"lowering speed, steering wheel locks up to where i can't turn not even a little, the check gauge light comes on and then the low oil light comes on and the car wouldn't move."
All indication that the engine has died, or is running at such a low rpm that nothing is working as it should. Fuel pump will not set a code.
Gregg-O is offline
post #3 of 8 (permalink) Old 11-20-2012, 11:41 PM Thread Starter
is it normal for the steering wheel to lock up though? i know better than to go to autozone and ask but i tried anyways and they were all surprised and shocked that the steering wheel locked up like they never heard it before..
post #4 of 8 (permalink) Old 11-20-2012, 11:44 PM
4x4high's Avatar
I'll bet the steering wheel did not lock up as you say but was VERY HARD to turn because the engine died and you no longer had power assisted steering. You could have an ICM going bad and i'm pretty sure that wont throw a code.
4x4high is offline
post #5 of 8 (permalink) Old 11-20-2012, 11:49 PM Thread Starter
Ok... well it seemed like it locked could be hard to turn but didn't want to try and force it. No need to get any further problems..
I'm no mechanic or big expert on cars... but when you mean "engine died" is that implying that it's going bad completely like it won't work.. or "engine died" as it shut off because there's something preventing it from running...
Thanks for the Replies by the way
post #6 of 8 (permalink) Old 11-20-2012, 11:59 PM
4x4high's Avatar
We mean that the engine died because something is going bad that either controls fuel or spark. The first suggestion was for a fuel issue and my suggestion is for the ICM (Ignition Control Module). The ICM is bolted to the front of the driverside head just above the ignition coil. Lots of times when they go bad the engine will restart immediately but as time goes on it usually takes a while for the ICM to cool down then the engine will start again.
4x4high is offline
post #7 of 8 (permalink) Old 11-21-2012, 12:03 AM Thread Starter
All right i'll look into those things see what may be the cause... thanks for the suggestions...
post #8 of 8 (permalink) Old 11-21-2012, 06:18 AM
As you will quickly learn, most AZ employees don't know sh!t about cars.
As others have said, when your engine dies, you loose the power assist for the steering. It didn't lock up, but will take full effort on your part to steer.
2005 Pontiac GTO
cletus284 is offline
