Throttle body bypass QUESTION - Page 3 - Chevy Impala SS Forum
post #21 of 49 (permalink) Old 12-05-2012, 03:16 PM
Mr pogo's Avatar
its same principle of refrigeration, as we do not have carbs I didnt think it germane to throttle bodies.
liquid under pressure introduced to low pressure atmosphere will flash and evaporate causing a temperature drop.
as our throttle body blades have nothing to do with liquids gasoline or otherwise, it wont happen.
and again, nobody Ive heard of in 9 years on this board has reported their throttle blades iced up on them.
Mr pogo is offline
post #22 of 49 (permalink) Old 12-05-2012, 04:30 PM
How would they even know their blades iced up???
Even in the 1980's, GM had heater plates beneath the carbs.
I was once blowing down my 80 gallon air compressor. The air was coming out of a 3/4" ball valve, and aiming at a piece of wood. A layer of ice formed on the wood, and it was 90 degree's outside, in the middle of August. By the time the compressor was out of air, the ice was 1/4" thick.
larryfs is offline
post #23 of 49 (permalink) Old 12-05-2012, 06:59 PM
MillerTimeGS's Avatar
It's like a choke. If its cold outside the coolant warms it up. If its warm already then it doesn't really matter. It's more of a preference more than performance. I did it so I can change the throttle valve easier.
Sent from my iPhone using AutoGuide.com App
MillerTimeGS is offline
post #24 of 49 (permalink) Old 12-05-2012, 09:34 PM
Originally Posted by larryfs View Post
How would they even know their [throttle] blades iced up?
Driver's foot might find out REALLY FAST.
Since we don't have fuel going past the throttle bodies anymore - since the 90s - just do the throttle body coolant bypass and enjoy.
1g1bl82p7rr127841
Rest In Pieces, In Peace
Marky Dissod is offline
post #25 of 49 (permalink) Old 12-05-2012, 10:47 PM Thread Starter
BIGBODY 94's Avatar
BIGBODY 94 is offline
post #26 of 49 (permalink) Old 12-05-2012, 10:59 PM
DiGGM95's Avatar
The closest I ever got to the throttle blades sticking open was in a civi 4.3'd 94 on its way to the JY. The blow-by was so bad, it sent enough oily crud over time up to the tb via the pcv vent to cause the throttle to stick open a little.
Nonetheless, never had an ice problem here....
1995 Caprice 9C1
1995 GMC Yukon
2003 **** CVPI
2009 **** CVPI
Youtube
DiGGM95 is offline
post #27 of 49 (permalink) Old 12-05-2012, 11:09 PM
Don't be skeerd. People in Minnesota,and North Dakota have bypassed theirs. One side benefit is much easier removal of the throttle body either for cleaning/inspecting,or to make it easier to get to something else. It also doesn't cost anything (I like that)
post #28 of 49 (permalink) Old 12-06-2012, 12:10 AM
Mr pogo's Avatar
again, those were carbed engines.
show me a port injected engine with an exhaust heat riser setup.
your air tank analogy fails.
water pools at the bottom of the tank after compressed air cools and condenses.
when the drain is opened and compressed liquid water is released from 80+ psi.
with that great a pressure difference the water will ice up.
the throttle blades see nothing close to that differential.
Mr pogo is offline
post #29 of 49 (permalink) Old 12-06-2012, 01:57 AM
coltonx3's Avatar
just do it lol
coltonx3 is offline
post #30 of 49 (permalink) Old 12-06-2012, 07:36 AM
X2 and stop with all the science and debating.
I'm with Pogo and most of the others that have done this. No real harm, no freeze ups along with some of the other benefits that have been described.
"bypass and enjoy"
