Throttle body bypass QUESTION - Chevy Impala SS Forum
post #1 of 49 (permalink) Old 12-02-2012, 09:33 PM Thread Starter
BIGBODY 94's Avatar
I live in ga is it necessary to do a Throttle body bypass , i heard it keeps the TB from iceing up in the winter,it dont get as cold here as up north,thoughts?? thanks
BIGBODY 94 is offline
post #2 of 49 (permalink) Old 12-02-2012, 09:36 PM
Mr pogo's Avatar
do eet.
Ive never heard of anybody icing up their tb.
Mr pogo is offline
post #3 of 49 (permalink) Old 12-02-2012, 09:46 PM Thread Starter
BIGBODY 94's Avatar
so still do it? its there a proper way to do it to a 96
post #4 of 49 (permalink) Old 12-02-2012, 10:32 PM
Absolutely,do it. They're all the same. After draining some coolant,remove the elbow from the steam pipe to the throttle body. Disconnect the line to the throttle body from the coolant reservoir,at the throttle body. Connect the line to the steam pipe,after trimming for length. It''s that easy.
post #5 of 49 (permalink) Old 12-02-2012, 11:10 PM
coltonx3's Avatar
i did mine on my 95 9c1 yesterday u dont have to cut the line from the reservoir just push the line on the steam pipe all the way ill put a pic in a lil
coltonx3 is offline
post #6 of 49 (permalink) Old 12-02-2012, 11:33 PM
Tim M. Killmeyer's Avatar
You got it backwards... the throttle body set up as it is (stock) keeps it from freezing up. You will never have a chance for it to freeze in GA so, yes, DO IT!
I live in Pittsburgh and never worried about it and as someone else said... I've never heard of someone icing up their tb.
Tim
Tim Killmeyer
Pittsburgh, PA
'95 BBB Impala SS
'06 Scion xB
'06 Honda Big Ruckus
Tim M. Killmeyer is offline
post #7 of 49 (permalink) Old 12-02-2012, 11:39 PM Thread Starter
BIGBODY 94's Avatar
i need a easy diagram to do this
post #8 of 49 (permalink) Old 12-02-2012, 11:40 PM Thread Starter
BIGBODY 94's Avatar
please do and @ tim ok will do
post #9 of 49 (permalink) Old 12-02-2012, 11:58 PM
Tim
If anything, bypassing the TB will PREVENT the TB from icing up.
(removing the coolant from it, hints, no liquid to freeze)
Pretty sure it was just for emissions (warm the air up, blah blah blah)
1996 9c1 L99, now w/ LT1. 208k and counting.
1996 SS BBB
BigB9000 is offline
post #10 of 49 (permalink) Old 12-03-2012, 12:59 AM
You should definitely do the TB bypass. I did it to my 95 Z28, 96 Impala and 04 Denali XL. Never had any problems and the temp dips into the mid 30's during the winter.
Someone on this forum posted a nice diagram on how to do the TB Bypass. Here's the link: Throttlebody Bypass?
I think the hp gain is 5-6hp average. Here is a link to a dyno before/after comparison chart from a 96 'Bird. http://www.ws6.com/mod-8.htm
xxxmalosoxxx is offline
