Fuel pump or tank not sealed properly????? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 12-03-2012, 01:56 AM Thread Starter
impalariviera's Avatar
Under hard acceleration especially in corners my car feels as if its going to cut off it does this for a split second then it takes off like its supposed to... Another thing I've noticed since changing the fuel pump, is after sitting for a few minutes my car has trouble starting unless I cycle the ignition a few times to prime fuel pump , it's as if the tank is bleeding off the fuel pressure . I'm thinking its the gasket (rubber) that goes in to seal tank on top. And light shed on my issue would be appreciated.....
1996 BBB 22inch asanti af115s . #41700 of 41934 order #366RY8. 2nd new trans level 3 this time and 373s
impalariviera is offline
post #2 of 4 (permalink) Old 12-03-2012, 09:41 PM
The tank seal has nothing to do with the fuel pressure supplied to the engine. Either a bad anti-drainback valve on the pump or a small leak between the pump and sending unit.
2005 Pontiac GTO
cletus284 is offline
post #3 of 4 (permalink) Old 12-05-2012, 03:33 PM Thread Starter
Thanks Cletus284 !! Ill definitely look into that as soon as I get my car back from the local speed shop they've taken almost a week and a half to do the 373s. I appreciate the reply....
post #4 of 4 (permalink) Old 12-13-2012, 04:34 PM Thread Starter
Well my fp went the other night and while dropping the tank I noticed that the quick connect hose in the middle came off by hand , so after putting it all together I made sure the hoses were all the way on and after installation it started right up .. Let it sit for about a half hour and voila it started right back up no more turning the ignition 3-4 times to prime pump!! Thanks for the pointers guys!!!
