P0174 trouble code - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 01-16-2013, 10:10 AM Thread Starter
john96ss's Avatar
P0174 trouble code
On my way to work this morning check engine light came on. P1074 is the code that came up. Any idea what is causing that?
Sent from my DROID RAZR using AutoGuide.Com Free App
R.I.P.96 IMPALA SS BBB R.I.P.
burned in my driveway in 2000
"96 DBL S" F.A.S.S.T/Region Of Doom
1996 Impala SS #2 "LUNA*SS" INC Cen*Cal
john96ss is offline
post #2 of 6 (permalink) Old 01-16-2013, 03:43 PM
angelo's Avatar
P0174 System too Lean (Bank 2)
a few things could be wrong....type p0174 in the search box and start reading... 8-)
-ALF out....
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is online now
post #3 of 6 (permalink) Old 01-16-2013, 06:21 PM
exhaust bolts broken, loose.
pcv fresh air tube cracked or broken
injector leaning out on the passenger side
p0174 is the lean code for bank 2
96 BBB CAI spintech ss304 exhaust,Tri-ys, Hotchkis everywhere,3:73s with eaton, 1.6cc/ls2 springs, black imp rims,dennys d-shaft,
98 Lumina 9c3, beater sold!
06 Impala magnaflows k/n
96 9c1 gone, not forgotten
96 BBB sold
ISSCA #2461
Bowtie 9C1LT1 is offline
post #4 of 6 (permalink) Old 01-16-2013, 07:12 PM Thread Starter
john96ss's Avatar
Gonna check it out this evening before i leave from work. Thanks
john96ss is offline
post #5 of 6 (permalink) Old 01-18-2013, 12:59 PM
angelo's Avatar
John96ss,
I had my oil change today and had the car scanned. I have P0174 too.
mine goes on and stays for about 60-100 miles then goes off and CEL turns off.....
Then in a day or 2 it does it again and CEL comes on.
As a step 1. we sprayed the MAF with MAF cleaner, and CEL was OFF when i went to mech today.
PCM only said it first happened 2300 miles ago and bank 2 was at 18% when Bank 1 was at 25%
mech said when it goes BELOW 25% it kicks the CEL on.....
I am just monitoring mine for now as car runs fine and pulls hard, just stupid CEL goes on....
Lastly i have a long hill on my daily commute and lean into throttle to get up the hill and that is common place for CEL to come on.....(cruz 1500 RPM @2000 RPM up hill)
-ALF out....
post #6 of 6 (permalink) Old 12-19-2013, 09:36 AM
angelo's Avatar
To the OP....did you get this resolved ? I just had a re-occurrence.....
Back in mid Sept i got my custom CAT-Back installed.
Today on about 5 mile in to my 30 mile commute to work the CEL came on. got P0100 and P0174.
Starting to wonder if the cold weather is making this happen ? Or the winter mix of gas ?
I think i will buy a 20gal treatment of Chevron until next oil change to have it looked at again.
-ALF out...
