Fuel pump or regulator - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 01-17-2013, 12:36 AM Thread Starter
I have a pretty simple question for anyone who mouight have the answer. I have a 96 SS and I recently started noticing some bad hesitation when exceleration. I check the fuel pressure and it's reading about 35 at idle. even if I rev the engine up it barely gets to 38 or 39. Is this an fuel pump regulator issue or a fuel pump itself problem
FEHLER1977 is offline
post #2 of 6 (permalink) Old 01-17-2013, 01:34 PM
I dont have an answer for you, but I think yours is headed in the same direction mine went. After the whole hesitation one day it started backfiring and running crappy. Then stop running. Won't start. I have replaced fuel pump and it's still doing same. I did not think of regulator though.
HeatherBelle is offline
post #3 of 6 (permalink) Old 01-17-2013, 02:02 PM
the fuel pump 'regulator" can be checked by pulling the vac line off the back and closely look for any signs of wet fuel on that rubber nipple...if wet it is bad
post #4 of 6 (permalink) Old 01-18-2013, 09:57 AM
^^^^ adding to the above, when my regulator went i never actually leaked into the vacuum line. it only leaked through the joint on the outside of the regulator. just fyi though.
96 Impala SS
142,989
What does it matter anymore?
02 7.3 drw 350. It pulls really heavy stuff.
2015 Camry xse is my new daily. It has electric steering!!!!
M0U35Y's_SS is offline
post #5 of 6 (permalink) Old 01-18-2013, 12:37 PM
and to add, run the car first then check the FPR nipple. Otherwise the gas may have evaporated if the car has been sitting.
post #6 of 6 (permalink) Old 01-18-2013, 03:37 PM
infomanSS's Avatar
Does it hesitate right when you push the pedal down, but then runs smooth...like when leaving a stop sign it hesitates then runs smooth? If so, I would lean toward the EGR valve.
David
09 Town & Country Ariel
08 Silverado 4x4 Ruby
03 Avalon XLS Iggy the Fierce
00 Infiniti I30 Harleyquinn
95 Impala SS Marlene...SOLD
90 DeVille M...SOLD
infomanSS is offline
