I am moving my thread from misc. to here. (Suggested). I few weeks ago 96 ImpSS Would run a little shoddy when cold. I thought tune up, but then one day it started popping, hesitating, backfiring. After that it just wouldn't start at all. She would just turn and turn. Checked all spark plugs and wires everything looked fine. Went on to fuel. I only put 94 high octane from shell. When key was put in ON position I couldn't hear fuel pump switch on and start prime. Now I have replaced fuel pump. And same ****. Won't run. Anyone have this problem before?
I have found a $30 investment in a fuel pressure gauge for LT1 is worth it. That will instantly tell you if it is a fuel pressure problem. Hypertech makes one but assume others do also
If FP is good...I would look towards the Opti as you note "popping/backfire"...previously. That is a very common signal Opti is dieing or dead.
Unfortunately codes are not always thrown. You can buy a code reader for OBD2 cars (96 and newer) for around $30 also at places like Harbor freight.
FP gauge and code reader along with a Haynes service book can go a long way in resolving problems.
with all this said "your" problem could be so many things but fuel and spark are two initial things to confirm. hard parts can fail but things like poor connections can cause havoc in tracing WTF is really going on.
This forum is full of great help...and some sarcasim.....as you may have discovered in the Misc section.
^Great advice! We had a club member with the same problem, couldn't figure it out, so decided to change the Opti and whan we pulled it out we could hear rattleing, so took the cover off and foung both screws for the rotor had backed out and off.
You can purchase a fuel pressure tester or alot of chain auto parts stores have them for rent. You will connect it to the schrader valve as in the pic above. Unscrew the black cap and install the tester.
You can then use that red wire I mentioned. That is just a jumper wire directly to the pump. That wire is used for testing and diagnostics, which you are doing. It will run the pump even if the key is off. When applying current to the pump, the gauge should read about 40-45psi. It should jump up almost instantly. If it takes more than 2 seconds, the pump is weak, it it doesn't reach at least 35psi, the pump is weak or shot.
I agree with the other posters, just one more piece of advice:
If you don't have a PCM tune to take advantage of it, filling these cars with premium gas is just throwing money away. Save a few bucks, it will run just fine on regular unleaded.
For those who don't know or seen them, the factory service manuals are huge...and...there's more than one for these cars. We have an old tech here that still uses them to troubleshoot stuff. What's real funny is he'll come in to me and ask me if I know anything about the problem. The stuff going wrong in these cars he tries to forget since we only see 2 or 3 a year.
Related Threads
Chevy Impala SS Forum
1.9M posts
42.8K members
Since 2000
