Fuel pump issues. I think - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 01-17-2013, 01:15 PM Thread Starter
I am moving my thread from misc. to here. (Suggested). I few weeks ago 96 ImpSS Would run a little shoddy when cold. I thought tune up, but then one day it started popping, hesitating, backfiring. After that it just wouldn't start at all. She would just turn and turn. Checked all spark plugs and wires everything looked fine. Went on to fuel. I only put 94 high octane from shell. When key was put in ON position I couldn't hear fuel pump switch on and start prime. Now I have replaced fuel pump. And same ****. Won't run. Anyone have this problem before?
HeatherBelle is offline
post #2 of 14 (permalink) Old 01-17-2013, 01:37 PM
angelo's Avatar
Step 1.
check schrader valve for proper fuel pressure. 37-42 psi
work backwards until you find why pressure is not up to par...
if pressure is good report back so.
-ALF out...
ECIRS #427 ISSCA #01978
96 WX3 DGGM Bone Stock except Bilstein 0929/1104 odom fade mod, FB & HP delete, lower bushing mod,Stealth Brake Bolt mod,9C1 air dams,160 stat,TB-Bypass,Hi-Miler Hoses,Taylor wires,SStudio TB Boot & K&N,Bonnies,Pypes-X,Spintech Super Pro Streets
CLICK ME !!!
angelo is offline
post #3 of 14 (permalink) Old 01-17-2013, 01:41 PM Thread Starter
Thank you will do.
post #4 of 14 (permalink) Old 01-17-2013, 01:53 PM
I have found a $30 investment in a fuel pressure gauge for LT1 is worth it. That will instantly tell you if it is a fuel pressure problem. Hypertech makes one but assume others do also
If FP is good...I would look towards the Opti as you note "popping/backfire"...previously. That is a very common signal Opti is dieing or dead.
Unfortunately codes are not always thrown. You can buy a code reader for OBD2 cars (96 and newer) for around $30 also at places like Harbor freight.
FP gauge and code reader along with a Haynes service book can go a long way in resolving problems.
with all this said "your" problem could be so many things but fuel and spark are two initial things to confirm. hard parts can fail but things like poor connections can cause havoc in tracing WTF is really going on.
This forum is full of great help...and some sarcasim.....as you may have discovered in the Misc section.
post #5 of 14 (permalink) Old 01-17-2013, 02:03 PM
streetcar2try's Avatar
You can purchase a fuel pressure tester or alot of chain auto parts stores have them for rent. You will connect it to the schrader valve as in the pic above. Unscrew the black cap and install the tester.
You can then use that red wire I mentioned. That is just a jumper wire directly to the pump. That wire is used for testing and diagnostics, which you are doing. It will run the pump even if the key is off. When applying current to the pump, the gauge should read about 40-45psi. It should jump up almost instantly. If it takes more than 2 seconds, the pump is weak, it it doesn't reach at least 35psi, the pump is weak or shot.
If it is an ACD, it has a LTW.
94 ImpSS, Currently a 24x 383 LTx. Built by Me.
Machining by Competition Automotive & Machine
Harness by BP Automotive (Bill)
Tuning by James at Shortuning.com
Mike Harris Crossmember
much, much more....
streetcar2try is offline
post #6 of 14 (permalink) Old 01-17-2013, 02:12 PM
Bad Imp's Avatar
^Great advice! We had a club member with the same problem, couldn't figure it out, so decided to change the Opti and whan we pulled it out we could hear rattleing, so took the cover off and foung both screws for the rotor had backed out and off.
Las Vegas Impala SS Club - SSincitySS.com
1996 Impala SS, Powerdyne Supercharger 6 psi, 3.73s, Snow Performance water/meth injection, Borla catback, F-Body MAF, Grotyohann long tube headers, Magnaflow cats, Hotchkis springs/front & rear sway bars, Bilstein shocks, Vigilante 3000 stall TC, Wilwood brakes, 20in Budnik Fontana's, and a couple of polished items
Bad Imp is offline
post #7 of 14 (permalink) Old 01-17-2013, 03:36 PM
Mr pogo's Avatar
as she has a 96 I would check for codes also, P0300 stored or active is common when the opti is starting to go.
Mr pogo is offline
post #8 of 14 (permalink) Old 01-17-2013, 07:21 PM Thread Starter
Is is all great I formation. I will post back tomorrow with results. Thanks a lot guys, I found out the hard way to stay away from misc. section.
post #9 of 14 (permalink) Old 01-17-2013, 09:36 PM
Banned
If you need to start a fire, the Haynes manuals are indeed a great way to resolve a problem.
DougDePew is offline
post #10 of 14 (permalink) Old 01-17-2013, 09:49 PM
I agree with the other posters, just one more piece of advice:
If you don't have a PCM tune to take advantage of it, filling these cars with premium gas is just throwing money away. Save a few bucks, it will run just fine on regular unleaded.
2005 Pontiac GTO
cletus284 is offline
