4 NEW auto zone WP's and weep still leaks ...WTF - Chevy Impala SS Forum
post #1 of 20 (permalink) Old 01-21-2013, 09:22 AM Thread Starter
I live in a part of Cali that about 2 minutes from Mexico... When I lived on the East coast my water pump swap would of been a 1 time thing...but I have had to change the water pumps I got here 4 times already in the past 6 months...
First my belt would squeak and power steering would try to go out but I would fix the problem..well that's what thought... And it's back again... Any ideas will help... I have a 96 impala .. Nothing modified... With 125,000 miles...
Tim96ss is offline
post #2 of 20 (permalink) Old 01-21-2013, 09:33 AM
Mr pogo's Avatar
if its not been done I would pull the knock sensors and flush the cooling system and engine with water.
Mr pogo is offline
post #3 of 20 (permalink) Old 01-21-2013, 09:36 AM
Banned
You said Auto Zone. IMO, you answered your own question.
DougDePew is offline
post #4 of 20 (permalink) Old 01-21-2013, 09:41 AM
Im gonna call BS on this. Ive replace 4 WP on the 4 different B-Bodys I have owned, all from Auto Zone. 2 of the cars I sold with working pumps, and the other 2 I still own without problems.
1996 9c1 L99, now w/ LT1. 208k and counting.
1996 SS BBB
BigB9000 is offline
post #5 of 20 (permalink) Old 01-21-2013, 09:44 AM
Banned
And you're more than welcome to do so. The quality of overall rebuilders, especially Cardone who is one of the largest, has fallen dramatically over the past few years. As you can deduce, the cheaper it's sold for (ala Auto Zone being one of the cheapest), the lesser quality the rebuild is.
To each his own.
post #6 of 20 (permalink) Old 01-21-2013, 09:50 AM
The Fooser Guy's Avatar
Thumbs down
To each his own.
+1 (or more)
We learned (the hard way, natch) that you don't even want to leave the store with a Cardone WP until you take it out of the box (at the counter), grab the tubes for the heater core hoses and try to wiggle them (they should NOT move - D'oh!). 4 out of 4 (including the one we had just installed, and removed to return - pissed) had 'removable' tubes. Quality ain't job one with them.
From what I can determine, the seal on the rear of the WP is the same part as the WP seal on the face of the timing cover. Now, if we can clever up a way to replace said seal....
$0.02
The Fooser Guy
The Fooser Guy is offline
post #7 of 20 (permalink) Old 01-21-2013, 10:15 AM
When you R&R the pump, did you replace the o-rings on the WP drive and driven shaft? If the coupler seizes on the shaft, it shortens the live of the WP bearing and seal. Its also a good idea to fill the coupler with wheel bearing grease to prevent rust.
2005 Pontiac GTO
cletus284 is offline
post #8 of 20 (permalink) Old 01-21-2013, 10:22 AM
Moderator
Goldmaster's Avatar
The cheap $50 rebuilt pumps are junk IMO. I worked at AZ and saw how many would come back. Now the new Duralast pumps have been pretty good to me. Those run about $100 or so. But they are new, not rebuilt.
Goldmaster is offline
post #9 of 20 (permalink) Old 01-21-2013, 10:25 AM
Water Pump
If you like AutoZone,then shop there. I've had more problem with them,and their product than all the other places combined. If you're tired of leaking water pumps,and they all will eventually. Then go electric. I've never been sorry. If I have to swap one out,it only takes 5 min.
post #10 of 20 (permalink) Old 01-21-2013, 10:45 AM
infomanSS's Avatar
I highly recommend converting to electric.
Keep your water pump housing, gut it, tap in a freeze plug in the back, bolt in pump in the front, add wiring, done.
Here's a list of ideas, notice how some come with the freeze plug and wiring...
http://www.summitracing.com/search/y...mps-electrical
David
09 Town & Country Ariel
08 Silverado 4x4 Ruby
03 Avalon XLS Iggy the Fierce
00 Infiniti I30 Harleyquinn
95 Impala SS Marlene...SOLD
90 DeVille M...SOLD
infomanSS is offline
