Did I just blow a head gasket? - Chevy Impala SS Forum
post #1 of 18 (permalink) Old 01-25-2013, 09:41 AM Thread Starter
ocala's Avatar
Unhappy Did I just blow a head gasket?
Here's the story,
My SES light has come on and off intermittently for the last two days. I also noticed what seemed to be less power. Also a strange exhaust smell now and then.
So today, I get in the car and when I go to start it - KLUNK, tried three times, each time - KLUNK. I could tell that the starter was engaging properly, with torque. NOT a battery issue.
On the fourth time the engine started. Sounded OK but very slightly rough, like possibly a cylinder misfiring.
After it started, I quickly saw A LOT of whitish steamy smoke coming out of the exhaust. More than I have ever seen before.
I gently pulled it back in the garage and shut it down. Drove my F250 to work and here I am.
So does this sound like a blown head gasket?
ocala is offline
post #2 of 18 (permalink) Old 01-25-2013, 10:31 AM
95Chwagon's Avatar
I think you answered your own question. Any amount of white smoke isn't a good thing. Another sure sign is losing coolant or rising temperature.
Is it both exhaust pipes? If it is only one, at least you only need to rework one side. Hopefully you caught it soon enough before you warped the heads.
96 Caddy, Triple Black/Grandpa Fresh
95 Cappy, Retired California Cop BBHP-120
92 RMW, Layin Wood on Billet Boyds
95 Chwagon R.I.P.
95Chwagon is offline
post #3 of 18 (permalink) Old 01-25-2013, 11:11 AM Thread Starter
ocala's Avatar
Can't say which side
I have what is like a Y pipe, exhaust goes from two to one 5" and back to two. I guess I could pull the exhaust and see which side...
ocala is offline
post #4 of 18 (permalink) Old 01-25-2013, 11:14 AM Thread Starter
ocala's Avatar
Regarding catching it before it warped the heads, could this be why the car wouldn't turn over the first three times?
There was NO overheating. I think the water level is OK, but I won't know untill I get home.
ocala is offline
post #5 of 18 (permalink) Old 01-25-2013, 11:22 AM
KW Baraka's Avatar
Originally Posted by ocala View Post
Regarding catching it before it warped the heads, could this be why the car wouldn't turn over the first three times?.......
Probably didn't start because you had coolent in the combustion chambers of the head that blew the gasket.....of coolent in the cylinder(s) on that bank.
You're lucky you have the steam coming out the exhaust.....I broke three starters (those KLUNKS can be killer ) before we determined that I had a blown head gasket.....never had (or at least, noticed) the white exhaust like you did.
Good luck!!
KW
KW Baraka is online now
post #6 of 18 (permalink) Old 01-25-2013, 11:43 AM
Barbarossa's Avatar
Send a message via AIM to Barbarossa Send a message via Yahoo to Barbarossa
1996 DCM Impala SS
14.38 @ 93.48
Build Date: 1996-12-05
ISSCA # 2360
Barbarossa is offline
post #7 of 18 (permalink) Old 01-25-2013, 12:47 PM
infomanSS's Avatar
Yep, I think that you blew a head gasket. Pulling the spark plugs should show which bank needs to be fixed.
On the bright side, it's a great opportunity to upgrade cam / heads / rockers / etc.
Good luck!
David
09 Town & Country Ariel
08 Silverado 4x4 Ruby
03 Avalon XLS Iggy the Fierce
00 Infiniti I30 Harleyquinn
95 Impala SS Marlene...SOLD
90 DeVille M...SOLD
infomanSS is offline
post #8 of 18 (permalink) Old 01-25-2013, 01:17 PM Thread Starter
ocala's Avatar
Originally Posted by infomanss View Post
on the bright side, it's a great opportunity to upgrade cam / heads / rockers / etc. :d
good luck!
just what i was thinking:d
ocala is offline
post #9 of 18 (permalink) Old 01-25-2013, 02:14 PM
i blew one last year driving and didnt know it..my temp gauge was broken and only after it shut dont did i realize oops...
funny thing is it was towed home and started right up and i was able to drive it up the driveway (tow guy coudlnt get up the hill)
we took out a plug and watched the stuff pour out..soup everywhere..not fun
also cooked all the oil and heard a noise on the lower end of the motor so decided on a rebuild
i have a new ATK engine now and i'm very happy and just rebuilt the tranny 2 weeks ago i have a brand new car!
2014 Impala LTZ; Sold and miss my 95 DCM 262K thanks to all who helped me over the years!; 87 caprice became my snow car in 2000 and it was laid to "rust" in 10/07 with 338K. Rebuilt trans at 308,000 (lasted pretty long I think); new radiator 330,000 (they said it literally disintegrated when they took it off)
luckydriver is offline
post #10 of 18 (permalink) Old 01-25-2013, 02:15 PM Thread Starter
ocala's Avatar
What is an ATK engine? Thanks
ocala is offline
