Air pump vacuum line missing ? - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 02-04-2013, 06:34 PM Thread Starter
cleaning the engine bay the other day came across what looks like a T fitting with a check valve in the air pump hose. this is right by the abs unit I capped it off sense I have not a clue if a hose hooks up to it or where it goes? anyone help me out here ?
Mattsrecording is offline
post #2 of 8 (permalink) Old 02-04-2013, 06:55 PM
It would help if you told us what year, model and engine type you have and include a picture if you can.
Attached is a link to the air pump setup on a 95 lt1/ l99,....
http://parts.nalleygmc.com/showAssem...rimLevel=15486
post #3 of 8 (permalink) Old 02-04-2013, 07:12 PM Thread Starter
94 , impala , lt1 , photo is already in the above post
post #4 of 8 (permalink) Old 02-04-2013, 07:16 PM Thread Starter
this diagram does the trick that T leads to Item 20 , anyone know the general location of item 20 ?
post #5 of 8 (permalink) Old 02-04-2013, 07:36 PM
Banned
Uhh......no, it doesn't seem to be
DougDePew is offline
post #6 of 8 (permalink) Old 02-04-2013, 08:10 PM Thread Starter
[/QUOTE]
http://www.impalassforum.com/vBullet...pictureid=2963
post #7 of 8 (permalink) Old 02-12-2013, 12:04 AM Thread Starter
Just a bump in my thread, can anyone trace the hose to item number 20 in the above diagram to find its location, I poked around under the hood and couldn't seem to find a loose solenoid or wiring.
post #8 of 8 (permalink) Old 02-12-2013, 09:21 AM
on the crossover tube that runs under the engine for the air system on the driver side, the solenoid is attached via a clip to that tube, a small diameter vacuum hose runs from that check valve to the solenoid
look by where the spark plugs leave the opti on the driver side there is a 4 prong plug in a little solenoid
1999 Camaro 38k
2012 yamaha vxs
lt1ssb is offline
