Check Engine Light after doing Air pump disable. - Chevy Impala SS Forum
post #1 of 17 (permalink) Old 02-22-2013, 04:38 PM Thread Starter
I have a 95 Impala SS and after doing the air pump disable it was causing me to get a CEL took it to a local shop to have it the code scanned it came back with a code 29 which is Air pump circuit. Is this common and if so what is causing it being a 95 I was under the impression that I didn't need a reprogram of my computer to do the air pump disable.
KameleonSS is offline
post #2 of 17 (permalink) Old 02-22-2013, 04:50 PM
Narc 9c1's Avatar
Check the pump fuse. I'm pretty sure you need to keep it and the relay in place so that the computer thinks it's still there.
95 9C1: Purchase Price: $1k -- T-56, AI 190cc Heads/cam, 355 Bottom End, 58mm BK TB, Intake Ported by AI, CIA Quad-1 Long Tubes w/ Export Pipes, 3:73s, Eaton Truetrac, SS Rearend (width), Eibach Springs, Bilstein Sport Shocks, PPM Front End, C3Fab 5/8 Extended Control Arms, SS Interior...
53 Studebaker Starliner: sold!
69 Grand Prix
Narc 9c1 is offline
post #3 of 17 (permalink) Old 02-22-2013, 04:53 PM
Banned
Pretty sure a search here would answer this
DougDePew is offline
post #4 of 17 (permalink) Old 02-22-2013, 05:18 PM Thread Starter
Pretty sure I did a search and did not find the answer. I am sick and tired of reading post and seeing someone respond with the do a search the search on here sucks now after they had the forum crash and lost all of the old info that was on here. If you look at the Air pump disable procedure it tells you that you are to remove the relay for the air pump you leave the fuse in place because it is also the same fuse for the under hood light which is working on my car so I know the fuse is still good.
post #5 of 17 (permalink) Old 02-22-2013, 05:46 PM
The Lazy Destroyer's Avatar
If you remove the relay you will get a code 29. Fuse and relay need to be in place.
-Blake
________Motoception Photography________
"Those who possess power define those who are powerless."
95 Caprice 9C1, 12.9 @ 103 mph, 1.74 60' - Bolt-ons car
96 Caprice Wagon - "Nomad SS"
94 RMW woody
The Lazy Destroyer is offline
post #6 of 17 (permalink) Old 02-22-2013, 05:48 PM
Narc 9c1's Avatar
This. I know Qalo's Manual says take it out but I left mine in.
69 Grand Prix
Narc 9c1 is offline
post #7 of 17 (permalink) Old 02-22-2013, 05:52 PM
94MI9C1's Avatar
You can only take it out if you have the ability to tune the PCM to ignore Code 29 for the Air Pump. Relay and fuse must stay in to keep the CEL off.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #8 of 17 (permalink) Old 02-23-2013, 07:54 PM
It's here, in the tech section: http://www.impalassforum.com/tech/en...p/air_pump.htm
FWIW, I'm sick and tired of answering the same noob questions over and over, but for some crazy reason I still do it. The crash was years ago, most common issues can be answered with a search.
2005 Pontiac GTO
cletus284 is offline
post #9 of 17 (permalink) Old 02-25-2013, 02:51 AM Thread Starter
Just because my post count isn't high in no way makes me a noob as a matter of fact I have been a member of the site longer than you. Plain and simple the search function sucks on here now because of the crash. Now back to the point I had already saw the link you posted and I did that but that is what caused the Check Engine Light to come when you pull the relay like it says to do in that link. That was my question why is it causing a CEL to come on when it says nothing about it and with it being an OBD1 it should not need to be reprogrammed like it says in that link.
post #10 of 17 (permalink) Old 02-25-2013, 06:46 AM
Crash,smash. I still can't believe how many times this excuse is given. I'm sure that one could find hundreds of threads dealing with this very issue in less than a minute using the "thread tools",or "search" function. You dislike the term "noob",and yet ask about a subject that has been beaten to death literally hundreds of times. So,what term would you prefer?
