vats - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 08-16-2009, 02:42 AM Thread Starter
vats
Hey guys,
After work tonight, I got stranded at work for an extra 10 mins because my vats kept me out of my car. Now, I have never had this happen to me. After my long, miserable day I just wanted to go home and this ticked me off.
I have a OBD1 to usb cable and freescan (so far). I would like to disable VATS from my car. I am sure this information would be somewhere in the past, but as of right now it is impossible to get to. Any help, pros/cons would be appreciated. thanks
chris
'94 LDM Caprice Classic L99
ISSCA Member #2309
94goldprice is offline
post #2 of 14 (permalink) Old 08-16-2009, 09:42 PM
Freescan can only scan and datalog. To disable VATS, you'll need a tuning program, such as C.A.T.S Tuner or similar.
2005 Pontiac GTO
cletus284 is offline
post #3 of 14 (permalink) Old 08-16-2009, 09:58 PM
Sinister's Avatar
My VATS problem was cured by a simple Ignition Cylinder change
1995 Caprice Wagon
Sinister is offline
post #4 of 14 (permalink) Old 08-17-2009, 03:27 AM
V8killer's Avatar
disabling VATS in PCM takes care of the fuel injection cut off, the module controls the power going to the starter when you turn the key.
so if the key is wrong or the resistor is not registering then fuel will shut off, but if resistor is working and the module is broken then no power will go to the starter when you try to crank it, depending on what your problem is you may or may not be able to fix it by disabling VATS in PCM.
i'll give you an example , and i'll use a stick shift car to make things easy:
1- If key/resistor was a problem you could push start the car but fuel would shut off, this is when disabling VATS would take care of this issue.
2- if module was the problem you could push start the car and it would keep running.
the short write up is you take out the relay in the module and jump #30 and #87 to bypass the VATS so it won't look for any signal coming from the ignition switch.
EDIT: i found some pictures on google cached pages of the guy who did this once:
STOLEN ON JUNE 8TH OR 9TH 2003 FROM TACOMA,WA
ISSF MEMBER #282
94 9C1,SS clone,DCM,SSRI,HA/F-body sway bars,3.42's Bonnies,floorshift,Stillen front,Smoothy rears,billet grille,white face Z-28 dash, Dynomax mufflers,Tri-Y,eibach,J&M control arms,NOS 100 shot,MSD digital+6&coil,MSD super conductors,metco safety loop,Dynotech driveshaft 12.98@110MPH
V8killer is offline
post #5 of 14 (permalink) Old 08-17-2009, 03:45 AM
V8killer's Avatar
here's a text only version of what i found cached on google:
lt1_s3 lt1_s3 is offline
lt1_s3
Send a message via AIM to lt1_s3
First, let me start off by saying that I have done countless searches with not much help.
Ok my question is can the vats only be deleted from the computer and not have resisters placed in line?
Also does anyone have a link to a vats delete post, the crash must have lost the ones I have seen befor.
I bought a remote start/keyless entry off a guy at work for $20 new in box and wanted to install it, isthis a pretty simple project?
Thanks John
__________________
Engine: 385 cid LT4, eagle 4340 crank, 6" H beams, 220cc AFR LT4's, 58mm BBK TB, tpis afpr, 12.5:1 diamond pistons, 1.6rr, LE2 cam, TNT wet kit
Transmission: T56 M6, steel forks, cf syncs
car: ?????????
I also have a 72 skylark GS 455/th400, a 95 Z28, and a 75 laguna S3
lt1_s3 View Public Profile Send a private message to lt1_s3 Find all posts by lt1_s3
Old 04-01-2005, 09:59 PM
95wagon 95wagon is offline
95wagon is an unknown quantity at this point
If you "turn off" VAT in the PCM it will no longer look for the signal from the VAT module before enabling fuel BUT The cranking inhibiter relay will still be there and will stop cranking so you must jump it also.
Gerry
__________________
334 RWHP@5900
12.83@104.59 NA (auto)
1.69 \"60\"
350 T56 6 speed
Drag strip pics and video
My Wagon
My W-31 Cutlass
95wagon View Public Profile Send a private message to 95wagon Visit 95wagon's homepage! Find all posts by 95wagon
Old 04-01-2005, 11:26 PM
gvillepoet gvillepoet is offline
gvillepoet
go to www.drdetailshop.com its a nice shop and will tell you everything you need. or jsut some helpful email from the guy. just recently got my remote start on. basically you buy a bypass relay. its only 20 something bucks i believe. i bought it from that website. and then bought the Valet 561t system off of ebay. for about half its retail price. works just fine and love to scare people in the parking garage.
__________________
96 BBB with all the basic mods
gvillepoet View Public Profile Send a private message to gvillepoet Visit gvillepoet's homepage! Find all posts by gvillepoet
Old 04-02-2005, 06:29 PM
lt1_s3
I refuse to spend the money on a bypass module, I will just use resisters. I omed the resister in my key and it read 1.26, does this sound right? I know I'm to look for the orange wire with the white stripe at the bas of the colum, do i just cut the wire and put the resisters in line?
__________________
car: ?????????
Old 04-03-2005, 02:28 PM
The fact remains that if you use resisters you have left the VATS module in operation.
Sure you have bypassed the key and lock cylinder, but if you are disabling the VATS why leave it operating at all? It can still let you down and is pointless if you are going to render the system inoperative with a resister.
If you turn off the VATS in the PCM (which was the original question) and bridge the wires at the inhibiter relay the system is completely disabled.
All that being said, mine is still all in place and functional.
Gerry
__________________
334 RWHP@5900
1.69 \"60\"
350 T56 6 speed
My Wagon
My W-31 Cutlass
Old 04-04-2005, 05:35 PM
ISSF MEMBER #282
V8killer is offline
post #6 of 14 (permalink) Old 08-17-2009, 03:47 AM
V8killer's Avatar
lt1_s3
I will delete the vats in the pcm but, my question is how do bypass it for the time being so that I can hook up my remote start.
Are the resisters placed in line on the orange wire with the white stripe at the base of the steering colum? If I do this and program out te vats in the pcm wouldn,t the vats be gone alltogether?
__________________
Old 04-06-2005, 02:21 AM
From what I can see in the service manual there is a .35 WHT/BLK #1073 and a .35 PPL/WHT # 1074
coming from the Theft Deterrent Module to the column.
The resister would go across those wires where they plug into the short harness that comes from the lock cylinder.
I can't tell you the colors of the short harness.
If you run a resister and turn off the VATS in the PCM the Theft Deterrent Module is still in operation. It still looks for the correct resistance (which your resister provides) and then grounds the Theft Deterrent relay windings so the starter will operate.
You could still have a module or relay failure that would cause a no crank.
This is why I feel that if you are going to defeat it, you should completely bypass it.
Gerry
__________________
334 RWHP@5900
1.69 \"60\"
350 T56 6 speed
My Wagon
My W-31 Cutlass
Old 04-06-2005, 05:45 PM
lt1_s3
how would I go about doing a complet bypass of the vats? I have a factory servise manual so a page # would also help. And again thanks for your time!
John
_________________
Old 04-06-2005, 07:27 PM
Nor-CalSS Nor-CalSS is offline
Nor-CalSS is an unknown quantity at this point
This is how you disable it according to QALO'SS Impala SS Handbook. Please save the image so I can delete it. Dont wanna use up server space. LMK if and when you save it. Once you save it you can zoom in to read better. Hope this helps you somewhat.
HTH
-edit- I took the pic down.
I dont know if you have already but you need to download QALO'SS Haandbook. The info you need is on page 50 and 51
HTH
ISSF MEMBER #282
V8killer is offline
post #7 of 14 (permalink) Old 08-17-2009, 02:34 PM Thread Starter
Thanks for the replies guys. I'm heading out to the dealer to have them check the resistance. I remember I checked it once and i read it being either key 7 or 8, but when I tried to measure it again recently I could not get a steady answer. Eventually, I want to completely disable it. But, for now, I just don't want to be left stranded. I have never had this happen to me, but I'm glad it only took me a 3rd try before it cranked and started.
ISSCA Member #2309
post #8 of 14 (permalink) Old 08-18-2009, 09:54 AM Thread Starter
Well I have figured out which key # I am using, so I ordered a pair off fleabay for like $16. So for only a couple more dollars I can get my keys cut too.
Let me get this straight, so in order to make VATS a thing of the past, I need to take out the module, jump the pins and program it out of my pcm?
ISSCA Member #2309
post #9 of 14 (permalink) Old 08-18-2009, 03:51 PM
V8killer's Avatar
yes .
ISSF MEMBER #282
V8killer is offline
post #10 of 14 (permalink) Old 12-18-2009, 03:54 PM
COFFEE's Avatar
How about if you want to FIX the VATS system. Would you need to get a new module and possibly a new key with matching resistor in it? Or is there more to do besides that?
"1994" Impala, Eaton posi w/3.42, Borla headers, Suncoast forced ram hood, cooler bypass, N/O kit, Trans by Neal Transmissions in "Snellville GA", 9C1/F41 springs w/Monroe Severe Service shocks, MSD Ignitions parts and then some. :-)
COFFEE is offline
