is it possible for a PCM to lose a tune?? - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 09-14-2010, 05:01 PM Thread Starter
can leaving it unhooked from a car for long periords or anyone know anyway that a pcm would lose a custom tune??
1999 Camaro 38k
2012 yamaha vxs
lt1ssb is offline
post #2 of 9 (permalink) Old 09-14-2010, 05:20 PM
jayoldschool's Avatar
No. The PCM cannot "lose" a tune.
jayoldschool is offline
post #3 of 9 (permalink) Old 09-14-2010, 06:00 PM
The pcm uses flash based memory. Your custom tune replaced the gm tune in the flash. It can never wind up reverting to anything other than what was flashed into it.
2010 Camaro 2SS LS3 TR6060 heads/cam/LSXr...500rwhp daily driver.
2005 Silverado RCSB 5.3/4WD
MikeOD is offline
post #4 of 9 (permalink) Old 09-15-2010, 06:28 AM
Gregg-O's Avatar
That's not to say that the PCM can still go bad.
Gregg-O is offline
post #5 of 9 (permalink) Old 09-15-2010, 09:23 AM Thread Starter
just curious cause it has been sitting in my closet for a year during my rebuild and am putting it back together soon
thanks for the replies
1999 Camaro 38k
2012 yamaha vxs
lt1ssb is offline
post #6 of 9 (permalink) Old 09-22-2010, 12:59 PM
I think it can. I use LT1 Edit \ OBD2 Prog to load new programs to my PCM. A couple of years ago I was half way through loading when my laptop hung and I was left with a car that wouldn't start and the PCM would not respond to my laptop. I emailed Bryan Herter for help and he advised to disconnect the battery and leave it for I think it was 15 or 30 minutes and the PCM would revert to factory settings. This I did and was able to start the car and then load up the new programing.
George
geowhite is offline
post #7 of 9 (permalink) Old 09-22-2010, 05:04 PM
Rocko350's Avatar
On a read failure, the pcm can be "reset" in this manner. On a flash failure, you have yourself an new doorstop, unless you get lucky. Sounds like you did!. Be forewarned. I have a stack of doorstops...........
Chris
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
Rocko350 is offline
post #8 of 9 (permalink) Old 09-27-2010, 10:02 PM
Chris
And even then, when resetting from a read failure...it will only revert back to the last program flashed into it.
The "factory settings" referred to, just means it will not remember any trouble codes it had stored, it will not remember any fuel trim data it had stored, and whatever was causing it to not power up will be cleared as well...but if it HAD a non-stock program in, and you are subsequently recovering from a read error...you will still have a non-stock program in it.
MikeOD is offline
post #9 of 9 (permalink) Old 09-28-2010, 03:47 AM
Thanks for the clarification. Now I don't have to panic every time I disconnect the battery.
George
geowhite is offline
Closed Thread
