1994 Caprice PCM changes for 3.08 to 4.11 gear swap - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 05-24-2011, 01:34 PM Thread Starter
What needs to change in the tune when changing from 3.08 to 4.11 gears for a 1994 9C1 LT1 caprice? I changed the gear ratio for the speedometer to work correctly. The trans is taking a long time to shift from 1st to 2nd. The rpm's are higher than I want. I want to drive a couple of hundred miles with the new rear gears before the T56 swap.
1996 DCM Impala SS
1994 DCM 9C1 Caprice
1981 LQ9 4L80E Trans Am
jeffd is offline
post #2 of 4 (permalink) Old 05-27-2011, 12:41 PM
Rocko350's Avatar
What software are you using?
Chris
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
Rocko350 is offline
post #3 of 4 (permalink) Old 05-31-2011, 01:19 PM Thread Starter
Tunercats OBD-I.
1996 DCM Impala SS
jeffd is offline
post #4 of 4 (permalink) Old 05-31-2011, 09:54 PM
Rocko350's Avatar
there is a tool built in to the software that makes corrections to all the tables at once. its in the drop down menu at the top of the software screen. fill out the data and select apply, then ok when the little screen says"hey buddy your gonna change a sh*tload of tables" then save and upload. Its possible the rpm and mph wot(kickdown) settings might let you hit the rpm limiter before you upshift at WOT, so change at your own risk.
Chris
Rocko350 is offline
