Emissions failed OBD fail - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 01-11-2012, 10:31 AM Thread Starter
Gregg-O's Avatar
Hi guys, 96 SS, OBD connector integrity = fail, MIL status = no voltage...fail, MIL light comes on when key is in on position. Car is running fine as always, I'm just guessing right now ..is this a blown fuse, or a bad wire at the connector? I thought I saw someone here say that power for the plug was on the same circuit as the cig. lighter? I am going to bed now as I've been up since 2:30 yesterday afternoon and went to the test after my 12hr night shift, I'll check back in when I get up and see what you think. I'll also try my code reader to see if I get a link failure on that. TIA.
Gregg
Gregg-O is offline
post #2 of 8 (permalink) Old 01-11-2012, 02:58 PM
her in cali - you cant convert to OBDI and pass.
I dont know if AZ is the same way...
1996 9c1 L99, now w/ LT1. 208k and counting.
1996 SS BBB
BigB9000 is offline
post #3 of 8 (permalink) Old 01-11-2012, 04:09 PM Thread Starter
Gregg-O's Avatar
No conversion it's OBD II.
Gregg-O is offline
post #4 of 8 (permalink) Old 01-11-2012, 04:18 PM
Ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh Im dumb.
I had the same problem, turned out a fuse was just out.
1996 SS BBB
BigB9000 is offline
post #5 of 8 (permalink) Old 01-11-2012, 04:26 PM
Mr pogo's Avatar
if it is the cig fuse and after fixing it you can hook up with your scanner, do not clear any inactive codes or disconnect the battery if there are no active codes.
if you do, the pcm monitors will reset which means you have to drive it for a couple days at least before you can get it resmogged.
96s are allowed two monitors to be flagged, inactive codes will not fail a smog.
Mr pogo is offline
post #6 of 8 (permalink) Old 01-11-2012, 04:49 PM
+1
Sometimes, its taken me weeks to get all monitors ready.
1996 SS BBB
BigB9000 is offline
post #7 of 8 (permalink) Old 01-12-2012, 12:45 AM Thread Starter
Gregg-O's Avatar
Ok, scan too reads nothing, zip, nada, it's just blank KOEO or KOERunning doesn't matter.. The cig. lighter fuse looks good. But I'll check it with my meter in the AM, but it looks fine to the naked eye.
Gregg-O is offline
post #8 of 8 (permalink) Old 01-12-2012, 01:21 PM Thread Starter
Gregg-O's Avatar
Fixed, note to self....check the right MOTHER&%$@ fuse. Guess a goodnights sleep helped...lol.
Gregg-O is offline
