96 caprice OBDI conversion - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 04-04-2012, 09:32 AM Thread Starter
My neighbor wants me to tune his 96 caprice. I only have OBD1 software. After I convert an OBD1 pcm with the resistors for the knock sensors I planned to flash a 95 caprice tune as a base file to start with. I know that the transmissions are different between 95 and 96. Will the 95 tune operate the 96 transmission correctly?
1996 DCM Impala SS
1994 DCM 9C1 Caprice
1981 LQ9 4L80E Trans Am
jeffd is offline
post #2 of 3 (permalink) Old 04-10-2012, 09:05 AM Thread Starter
anyone?
1996 DCM Impala SS
jeffd is offline
post #3 of 3 (permalink) Old 04-12-2012, 12:40 PM
Blue Wail's Avatar
Yes, it will shift correctly. The transmissions are the same.
Also, you don't have to solder in resistors to the PCM, just replace the knock sensors on each side of the motor w/ ones from a 95.
-Nab
10.87 @ 121 mph (MD Int' Raceway 11/14/2016)
Dry 150 shot through MAF (.062 jet)
Junk 355, Stock Iron heads; CC502 cam
4500 ati Turbo 400 4.56
9C1 'Anteloupe' 3300 lb
(World's lightest full-frame Bcar)
Blue Wail is offline
