L99 cylinder volume - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 11-24-2012, 03:54 PM Thread Starter
Send a message via AIM to bigblock671
L99 cylinder volume
Does anyone know the cyl volume on a L99?
350 musi alum heads 503 cam 11.93 1.62 60@112 n/a 11.50 @115 1.52 60 100 shot
bigblock671 is offline
post #2 of 8 (permalink) Old 11-24-2012, 05:32 PM
4x4high's Avatar
It is 538.92 cc's
The mathematical equation is bore (3.736) x bore (3.736) x stroke (3.00) x 12.8704 = swept volume of 1 cylinder
4x4high is offline
post #3 of 8 (permalink) Old 11-24-2012, 11:23 PM
KW Baraka's Avatar
Originally Posted by 4x4high View Post
.......The mathematical equation is bore (3.736) x bore (3.736) x stroke (3.00) x 12.8704 = swept volume of 1 cylinder
........hell, I'd just do 4.3 divided by 8 = .......
That would get you into the neighborhood .
KW
KW Baraka is offline
post #4 of 8 (permalink) Old 11-24-2012, 11:48 PM
4x4high's Avatar
KW
Well assuming you mean divide 4.3 liters by 8 that would only give you the liters for one cylinder NOT the CC's of swept volume. Now assuming you mean to divide the 262 cubic inches that would only give you the cubic inches for 1 cylinder and still not the CC's of swept volume.
I'm assuming the OP is trying to figure out either his existing compression ratio or needs the info to change the compression ratio by using heads with a different combustion chamber volume or pistons to achieve a different compression ratio.
4x4high is offline
post #5 of 8 (permalink) Old 11-25-2012, 12:15 AM
91ss's Avatar
Or maybe he is looking for the right value to put into his bin file since he's in the PCM section?
91ss is offline
post #6 of 8 (permalink) Old 11-25-2012, 01:06 PM
GM's answer for this value is
537.94
1g1bl82p7rr127841
Rest In Pieces, In Peace
Marky Dissod is offline
post #7 of 8 (permalink) Old 11-28-2012, 04:50 PM
Rocko350's Avatar
Wonder what he's up to? Didn't get to see him at all this year. Maybe putting a blower on it? Awwrighty Keith, whatcha doin?
Chris
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
Rocko350 is offline
post #8 of 8 (permalink) Old 11-28-2012, 07:15 PM
Volume of any cylinder is: Height*pi*(diameter^2)/4.
2005 Pontiac GTO
cletus284 is offline
