AC Delco spark plugs gap difference - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 05-30-2013, 10:01 AM Thread Starter
Berns's Avatar
Hello All,
I have been reading thru some threads for spark plugs but most are for the LT1 and what ever information was available prior to the crash for 91-93s no longer appears when clicking on the topic. I am doing a full tune up on my car this weekend cause I have to get it smogged. I was searching Napa and noticed that part no CR43TS which is what the car came with from factory state gap at .35 but the rapid fire plugs state gap at .45. Why the difference?
Car info: 1993 Caprice LTZ - L05 mostly stock with only upgrades being MSD cap and rotor and soon new MSD wires, MSD coil, dual after cat exhaust, tranny with shift kit and JET chip.
http://www.napaonline.com/Catalog/Re...270&Ne=1000000
1993 Caprice LTZ/LS
Smoked headlight, tinted 91 tails, LED interior and exterior, JET chipped, MSD ignition, sounds with Kenwood unit, 20" IROCS w/ 255/35 20 Falkens, dual after cat exhaust and bowtie tips, modded air box, WAY MORE TO COME.....
Berns is offline
post #2 of 6 (permalink) Old 05-30-2013, 03:11 PM
Rocko350's Avatar
Depending on engine condition, the rapidfire plug that is gapped at .045" will idle cleaner and should smog better vs the standard plug gapped at .035". It can conduct its spark energy better and can also shed a bit more heat. Be forewarned though, in cold temperatures with ethanol gas and TBI expect a bit of hard starting and some economy drop off with the rapidfires. The difference between the two is the materials the plug is made from, and the amount of heat each is able to deal with since the rapidfires conduct heat to the cooling jacket a bit quicker.
Chris
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
Last edited by Rocko350; 05-30-2013 at 10:51 PM. Reason: forgot to profread. jay caught me VVV
Rocko350 is offline
post #3 of 6 (permalink) Old 05-30-2013, 06:44 PM
ghetto wagon's Avatar
I never used Rapid fire plugs. I always used the stock AC delco CR43TS for a 350 or the CR45TS for a 305. What is strange is that the TBI Trucks used CR43TS plugs. They cost $12.50* -20 for a pack of 8, They last 30k if your engine is in good shape.
* AC delco spark plug rebate.
The forum is dead
So is the car's battery from sitting.
Waiting for someone to jump it. Tabarnak!
Finally bought a battery, now the tires are flat spotted
ghetto wagon is offline
post #4 of 6 (permalink) Old 05-30-2013, 08:23 PM
jayoldschool's Avatar
When HEI first launched, GM spec'd gaps as large as .060. They brought that number down to .035 (not .35, btw, that's HUGE). Anything between .035 and .045 will work reliably.
jayoldschool is offline
post #5 of 6 (permalink) Old 05-31-2013, 09:55 AM Thread Starter
Berns's Avatar
Thanks to all for your help. I think I will take advantage of the AC Delco rebate and get the rapid fires since I do not drive it daily and the cold temps are not as bad in Cali as other places.
1993 Caprice LTZ/LS
Berns is offline
post #6 of 6 (permalink) Old 05-31-2013, 07:22 PM
I think the rebate ends today (May 31st) unless they extended it
The forum is dead
