Low Beams do not work - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 04-28-2010, 04:04 PM Thread Starter
josephchevy5596's Avatar
Whats going on people haven't a headlight problem my low beams will not come on. every thing else works except the low beam headlights. Parklights are on high beams work but no low beam. i was tryin to find the headlight relay but I can't seem to locate it does any one know where this relay is. If not i'll probably just replace the dimmer switch and see if that works.
94 Fleetwood 383 Stroker on 26"s aka The Beast II gotta love it!!!!!
josephchevy5596 is offline
post #2 of 9 (permalink) Old 04-28-2010, 06:48 PM
Headlamp relay is below the dash, to the left of the steering column. its the one in the middle on the lowest row of relays.
2005 Pontiac GTO
cletus284 is offline
post #3 of 9 (permalink) Old 04-28-2010, 08:24 PM
it's the dimmer switch, auto zone has it for about $20,
96 9c1 (wreck at 267.xxx, gone)
96 9c1 295/50/15 on 15-8 front n 15x10 on rear, 3.73s, sligthly modified and lot of that.
95 9c1, intake, exhaust and some
95 fleet, stock but work in progress.
95 fleet, intake, exhaust, suspension
94 caprice st.wagon, 3.42s, slightly modified
2001 bmw 740il
caplt4 is offline
post #4 of 9 (permalink) Old 04-29-2010, 12:19 AM
Before you change anything make sure your bulbs are good. As a parts guy, I've had a number of people want to buy relays, switches etc when in reality they just needed to new bulbs. Check the easy stuff first.
94 Fleetwood
94 SS daily driver, deletes,T56,Suncoast hood,sliding sunroof***SOLD***
darth is offline
post #5 of 9 (permalink) Old 04-29-2010, 02:04 AM
IMPALASS_RIDER's Avatar
Send a message via AIM to IMPALASS_RIDER Send a message via Yahoo to IMPALASS_RIDER
x2
ive been threw 3 lol
'95 DCM < unladylike *been down since jan 17th 2010*
'95 DGGM 383, 100 shot *RaceCarWithAC*
2013 F250 LIFTED on 37's
2012 Accord
'95 BBB SOLD
IMPALASS_RIDER is offline
post #6 of 9 (permalink) Old 04-29-2010, 05:06 PM Thread Starter
yeah i just check out the wireing diagram and noticed the relays are before the dimmer switch which means the dimmer has a heavy current load going throu it. I"m going to add 2 new relays after the dimmer switch this weekend, which will make the dimmer just a switch to run on the relays instead of the headlights. Is any one with me on that, that might be confusing to sum but i do this to all my project old school cars, to keep from buring out headlight switches and dimmer switches.
post #7 of 9 (permalink) Old 05-02-2010, 10:15 AM
chevmdnss's Avatar
Sounds like a great plan......... We definitely have a weak wiring system for the lighting on our cars.
You should ACTUALLY think about upgrading the entire harness. DO a <search> for Whisperjet... quite a few threads about it.
Sean ---> 1993 Caprice Wagon
Former rides
96 Fleetwood $$ -- 2008 Magnum RT -- 2011 Ram Crew Sport
B2200|96 RMW|91 Caprice Wagon|92 Olds CC|95 9C1
chevmdnss is offline
post #8 of 9 (permalink) Old 05-06-2010, 06:47 AM
josephchevy5596
you fix the problem, change the dimmer switch or haven;t got to it yet? just wondering what was the out come
2001 bmw 740il
caplt4 is offline
post #9 of 9 (permalink) Old 05-11-2010, 02:46 PM Thread Starter
Replaced the dimmer switch gotta new problem now thou finish puttin the dimmer switch in and soon as i left the house the brakes started lockin up
