Parking Brake Release - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 10-18-2010, 01:10 PM Thread Starter
cason234's Avatar
Hello all,
I've had my Fleetwood for a year and a half, and one thing on it has never worked, but I'd like to fix it..... the parking brake.
If I put my foot on the parking brake lever and push it to the floor, it simply pops right back up and will not stay depressed. I can tell that it will hold the car (just to check, I've pushed on the lever while the car was in gear), but the lever won't 'catch'..... ie: it just jumps back to the 'released' position and won't stay down (in other words, the problem is at the front of the car, not the brakes themselves).
Any others experience the parking brake not catching? Is it possibly a vacuum issue? I've never really looked into how it functions, but I figure before I rolled up my sleeves, I'd check the list here.
Thanks in advance for your help!
1994 Hardtop - Black on Black / 4.10's / Auburn Posi / Trifecta PCM / Corvette starter / 1G starter cables / Traction Control relocate / Denny's Aluminum Driveshaft / Hotchkis Springs / Bilstein Shocks / BMR Sway Bars / C3 Fabrication LCA's / SS Wheels / MOMO 10" Steering wheel / Homemade CAI / Black Troll Hair seatbelt pillars / Summit Turbos / cat delete / 3" stainless tailpipes
cason234 is offline
post #2 of 9 (permalink) Old 10-18-2010, 05:45 PM
Try it in Park. There may be a feature that auto releases it in any gear.
96 Black is online now
post #3 of 9 (permalink) Old 10-18-2010, 08:53 PM
I had the same problem. I figured out it had to do with the tooth mechanism. I bought another parking brake assembly from a forum member. I replaced it and it works fine. After I got the non-working assembly out, I still couldn't figure out the problem. Good luck!
skill3 is offline
post #4 of 9 (permalink) Old 10-18-2010, 10:03 PM
The ratchet assembly is not engaging the sector gear. You may have a sticky, or worn ratchet arm. Try shooting it with some WD40 or equivalent. The release arm may be bent or the cable end is caught on the wrong place.
1991 OCC 461 (.030 over 454) BBC, 3.23 posi, flash to pass, drop spindles & springs, Impala rims, Recaros, MOMO/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...sed-parts.html
post #5 of 9 (permalink) Old 10-19-2010, 03:15 PM Thread Starter
cason234's Avatar
Thanks guys.... I'll take a closer look at the mechanism itself. (BTW: this condition exists in any gear, Park or Neutral included)
appreciate the responses.
cason234 is offline
post #6 of 9 (permalink) Old 10-19-2010, 03:16 PM Thread Starter
cason234's Avatar
Was this tough to get at? How much work involved? I'm comfortable tackling anything, but it sure looks like it's buried in there!
cason234 is offline
post #7 of 9 (permalink) Old 10-19-2010, 07:04 PM
It wasn't that difficult. I did it completely by myself, but a helper would be nice. I started by unbolting the top nut from the firewall in the engine compartment. There is also a bolt that goes from the assembly to the kick panel area (at least I think there is). The easiest way to remove the brake cable is after unbolting the assembly. Reverse to install. I would buy the replacement assembly first. Having it in hand gives you a guide. I think it took me about 30 minutes to do the whole process.
skill3 is offline
post #8 of 9 (permalink) Old 12-27-2011, 08:43 PM
Same problem. Going to investigate mine in the AM.
joflewbyu2 is offline
post #9 of 9 (permalink) Old 12-28-2011, 08:41 AM
Just got to it this morning. Took the under dash cover off and shined a flash light. Noticed the slack in the parking handle cable. The lever was rusted. Sprayed lubricant and back in business. Worked the lever a little and works like a charm.
