9C1 Springs on Fleetwood with Stock Tires - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 02-28-2012, 01:03 PM Thread Starter
After exhausting searching, I have to ask if anyone knows if replacing stock FE1 springs on on a 96 Fleetwood with stock 9C1 springs would lower the Fleetwood at all, and if so how much or would it interfere with the stock tire height.
The car sits way to high and floats around way to much, a two inch or so drop would be perfect. I'm a little scared of cutting the springs and would rather replace.
Any help is appreciated. Thanks!
1996 Fleetwood Brougham Triple Gray
1995 Black Impala SS
1993 Corvette 6 Speed (Black G/S Clone)
2005 Yukon XL
BigDaddyJames is offline
post #2 of 11 (permalink) Old 02-28-2012, 09:53 PM
9C1 springs should be virtually the same static height. They will take care of that float issue, though. To get a 2" drop w/ a stock GM spring would mean going to SS springs.
2005 Pontiac GTO
cletus284 is offline
post #3 of 11 (permalink) Old 02-29-2012, 07:48 AM Thread Starter
Thanks! Would swapping the stock FWB springs for stock SS springs require a wheel alignment or interfere with the stock FWB tire height?
2005 Yukon XL
post #4 of 11 (permalink) Old 02-29-2012, 07:05 PM
Any spring swap is going to require an alignment. I ran SS springs on my Fleetwood with 235/75/15 tires and didn't have an issue.
2005 Pontiac GTO
post #5 of 11 (permalink) Old 03-01-2012, 07:51 AM Thread Starter
Thanks, the real question is where to find stock SS Springs. There are no available replacements for them. I may have to start looking at eibach style lowering springs for caprice and try to find something that will match the stock SS spring height. I'm not sure of the availability of something like that though.
2005 Yukon XL
post #6 of 11 (permalink) Old 03-01-2012, 09:20 AM
Eerthing cletus says. Plus, the OEMs use a very light springrate. Do not cut the stockers and expect anything other than just bottoming out real quick. Ask me how I know.
After trying some Carquest replacements and used Hotchkiss I settled on old SS OEM coils all around - love 'em.
post #7 of 11 (permalink) Old 03-01-2012, 11:16 AM
Badass94Cad's Avatar
Check Moog for some "stock replacement" style springs for the SS.
IIRC they're made by a company called Cheeta, though I'm not sure "the public" can buy their springs directly. They manufacture and sell to brands. They're a nice quality spring though.
1994 Cadillac Fleetwood Brougham (Light Adriatic Metallic) - 2 ProHopper pumps, 6 batteries, 13" 100 spokes, Firestone FR380, Edelbrock headers, Flowmaster, Magnaflow cats, K&N, Taylor, NGK...
1994 Cadillac Fleetwood (Medium Taupe Metallic) - sewer pipe, K&N, Hotchkis springs, KYB shocks, SS sway bars, SS rims, TransGo, DynoMax, Taylor, NGK, RM climate control, MP3...
2011 Buick Regal CXL (Silver Dust Metallic) - 2.0T 6-speed
Badass94Cad is offline
post #8 of 11 (permalink) Old 03-01-2012, 11:43 AM Thread Starter
Thanks, I tried moog and delco there are no listings for stock SS Style springs. So I'll have to keep looking for something that's the same height, I think a lower spring for an SS would be too low for my FWB
2005 Yukon XL
post #9 of 11 (permalink) Old 03-01-2012, 01:09 PM
Do a search for the Moog springs. I know people have said on this forum (Suspension, not Fleetwood) which ones to use.
As for lowering springs, Eibach is a little lower than stock, Hotchkis lower than that, and then there's Sprint and some others that are very low. I've had Hotchkis on 3 Fleetwoods. It was low, but not TOO low (not even low enough for me!). You could always try the Eibach.
post #10 of 11 (permalink) Old 03-01-2012, 01:14 PM
Crappy pics, but this is what I have handy at the moment. Taupe is on Hotchkis springs and SS wheels.
ID:	22839   Click image for larger version
