WTB 96 fleet ECU - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 03-15-2012, 08:53 PM Thread Starter
Send a message via AIM to Bigbusa
WTB 96 fleet ECU
Need a 96 fleet computer mine is not reading at the obd port and there is power coming to the port...Thanks in advance
96 Fleet LTx ..CPT level 3 4l60,edge 3000,3.73 ,eaton,bilstiens,spohn f&r sways,lca\'s ,cia headers ,Delteq MSD *** 4,noair pump,cat,egr,pcm forless obd1 conversion,ramit cai,x pipe,borlas,mooged,ssbc calipers and rotors,walbro,asanti 22 staggered af 124 ,riv console,garys cables,prtd LT4 int ,396 lunatti crank,ross pistons coated,AFR rev kit......
Bigbusa is offline
post #2 of 7 (permalink) Old 03-16-2012, 12:21 AM
CoupeDTS's Avatar
you sure the right wire has 12volts? Mine did the same thing, I had to run a seperate 12v to it.
Known for slammin' Cadillac Doors!
1996 - Fleetwood Brougham Black on Black V4P
1983 - Coupe Deville - Street Custom Show Lowrider
1970 - Calais 4dr HT
CoupeDTS is offline
post #3 of 7 (permalink) Old 03-17-2012, 08:04 AM Thread Starter
The scanner is powering on but says it could not communicate with ecu,from what I looked up thats a computer problem..
Bigbusa is offline
post #4 of 7 (permalink) Old 03-17-2012, 06:28 PM
95BRMW's Avatar
Try to get the codes through the climate control. Hold the temp up and off button for a few seconds until the display display 00 then hit the out temp button to display the codes if there are any.
1996 DCM SS 216k
1996 Black RMW 158k
1995 DCM Roadmaster Wagon 118K
1992 Olds CC 5.3l LS swap 181k
1994 Fleetwood 160k
1975 Impala Coupe
95BRMW is offline
post #5 of 7 (permalink) Old 03-17-2012, 06:48 PM
CoupeDTS's Avatar
that doesnt display all the codes on a 96 because its a obd2 and that setup is for a obd1.
try car-part.com to search junkyards.
CoupeDTS is offline
post #6 of 7 (permalink) Old 03-17-2012, 09:08 PM Thread Starter
I did that and I only gota few codes but it needs a tune and it seems the old computer wont take one....I also want to checj my oil pressure and the obd with the climate does not show that...Does anyone know the part # on a 96 fleet ecu
Bigbusa is offline
post #7 of 7 (permalink) Old 03-25-2012, 08:04 PM
RoadmasterB's Avatar
part # is 16214399
fits 96 corvette,caprice,roadmaster,camaro,firebird,impala ss
1996 only
Wagonless
MY 94 TRUCK IS A HYBRID I HAVE $500 IN IT
RED CAB BLACK FRONT CLIP TEAL BED 97 FRAME 4.3 5 SPEED GETS 28 MPG AND ITS A CHEVY
I HAVE A BUNCH OF CHEVY TRUCK'S
I AM 88MCLS ON EBAY 100% FEEDBACK
I PART OUT GM CARS AND GM TRUCKS
RoadmasterB is offline
