9/2014 - OE-spec body mounts - possible GP - Chevy Impala SS Forum
 1Likes
post #1 of 86 (permalink) Old 10-01-2014, 09:28 PM Thread Starter
Navy Lifer's Avatar
Over the years, there has been much discussion about body mount servicing, upgrades to 9C1 configuration, addition of the "Mueller Mod", etc. There are quite a few threads--both before & after the Great Aug. 2009 Data Loss (some of which may now be restored).
Without attempting to cite all of the threads, here are a couple to put the issue into perspective:
Rubber Body Mount Bushing Question/ Suggestion
Any interest in Meuller B-body bushing reproductions ?
Other than what some B-body owners have managed to hoard, the supply of OE body mount parts is now virtually exhausted. There are some aftermarket suppliers that have kits in both rubber & polyurethane that can be used, but generally it has been with mixed results.
For those who would be interested, there may be an opportunity to get new rubber body mounts made that are as close to OE in all respects as possible, through a reputable aftermarket source--at this point, who that may be is not important.
The reason for this new thread is to gauge interest. The supply source would need to buy a minimum of 5000 pieces (assuming that will be a mix of specific parts/mounts that would make up a full car set). The supplier would be more interested in doing this as a quantity buy--ie. Group Purchase--both for their own ROI (return on investment) and to be able to offer the kit at the best price possible, by way of the savings being passed on for a larger quantity buy from their source.
The mounts used on B-body are not totally unique to that platform--there were many GM vehicles from about 1973 all the way to the 96 B that used similar or many of the same mounts--as the supplier has more than the B-body in mind when making their plans for having these mounts made.
The configuration that would result and be offered for a Group Purchase would MOST likely be the 94-96 9C1 (7B3) mounts, and the "Mueller Mod" lower cushions ARE NOT anticipated to be part of the offering. For Impala SS restoration purists, I'm not sure what can or would be done to provide the "exact" mounts for non-9C1 cars.
A full replacement set of 14 (7 per side) upper/lower body mounts, as appropriate (#5 is upper only), including bolts, spacers, washers, etc, is what is anticipated (not certain whether there will be radiator core support cushions as part of this effort). Kit cost would likely be in the $250 - $300 range for everything. That is comparable to some of the aftermarket rubber kits offered for other GM models currently--and no doubt competitive with the OE parts, IF they were still available.
Again, the real purpose of opening this thread is not to extend discussion or dissect the mount issue further. At this point, what is needed is to be able to demonstrate, to the supplier, what the level of interest for this is, in the 91-96 B-body community.
To be clear, I am only a facilitator--I will have no financial interest, nor any direct involvement beyond gathering the information requested here or, if requested, to provide technical data, samples or other information to the supplier, that might be useful to help bring this effort to reality. If a GP results, I do not expect to run it--that will be either the supplier or (and I'm stepping beyond a possible boundary here) perhaps a club could organize & run it--and if they make money in the process, good for them for getting involved!
Whether you post here, PM me, e-mail me (or all 3), the first thing needed is a "show of hands"--please respond, if interested!
Who is in?
Bill Harper
ISSCA #127
inov8r@windstream.net
Navy Lifer is offline
post #2 of 86 (permalink) Old 10-02-2014, 02:51 AM
pjslover's Avatar
I'm Interested
Let's do this !!!!!
ORIGINAL OWNER
1st Base "Sewer Pipe" Mod
and Home Base Delete
"X" Pipe
Sequential Tail Lights
PMT Extended Upper and Lower Rear Control Arms
Stealth Brake and Metering Bolt Mod
Complete LED Interior, Including Radio
VATS Bypass
LED CHMSL
Camero 6 Speed EGR Valve
Moser Engineering Axles
Complete Front End replacement with MOOG parts
355,000 Miles and Counting
New Engine and Trans @ 304,550
Bilstein Shocks
Vogtland Springs
pjslover is offline
post #3 of 86 (permalink) Old 10-02-2014, 05:35 AM
Scott Knight's Avatar
Bill, how timely (for me). I am just resurrecting my project and was looking around at options since the mounts are in pretty bad shape (both pictures below are of the same bushing). There is a set of Energy Suspension urethane bushings on the shelf that I bought probably 10 years ago, but would much rather have a set of 9C1 bushings. If I knew then (back when they were readily available) what I know now, I would have bought about 5 sets just to have handy.
If this works out, I will happily take two sets.
ID:	96706   Click image for larger version
Scott Knight
1994 Impala SS (finally under construction)
1995 9C1 6-speed (put back to stock and sold)
1995 9C1 (sitting abandoned since 2002, likely waiting to be crushed sometime in the future)
"If my answers scare you, then you should cease asking scary questions"
Scott Knight is offline
post #4 of 86 (permalink) Old 10-02-2014, 06:05 AM
Heck yeah, I would be interested in a set. Would like to see the price lower though. Thanks for trying to get this finally done.
post #5 of 86 (permalink) Old 10-02-2014, 10:02 AM
Bushings
Bill,
I am in for at least one set, probably more.
Thanks for your effort.
Ken
Ken Hennessy is offline
post #6 of 86 (permalink) Old 10-02-2014, 03:55 PM
ISSF Honey Badger
Big Kahuna's Avatar
Send a message via AIM to Big Kahuna
Great idea, thanks for bringing this up. I would definitely be in plus we can send this around to local clubs, etc.
SAVE THE DATE: 2017 ISSCA NATIONALS in INDY July 26-30!!! You don't want to miss this one! Time to sign up! Go to:http://issca.org
*BEST of ISSCA 2005 & 2013 * ECIRS CHAMP 2004, 2006, 2012, & 2014 * ISSCA Spirit of Chino 2012 * SSHS '10 Class A Champ in Eriks TBSS
* 19 ECIRS (East Coast Impala Racing Series) event wins * Bunch of other stuff blah blah* www.ecirs.net - come race with us...if you dare!
-94 BBB: Big Block RamJet 502 - SOLD 2014!
-95 BBB: Brickyard 400 Pace Car aka Chino SS
-95 BBB: The one and only Flambe SS396 - 4600+ lbs of fun - Original Owner 2-21-95 - HOLY SH1T - 149K miles
........11.72 at 115 baby shot / 12.23 at 111NA
-96 BBB: Cliff's clean, perfect, 38K mile car - SOLD 2008 - wrecked by Cracka
- 96 BBB: SSato's Supercharged Best of ISSCA winner - 31K miles - SOLD 2006 - wrecked by Shane
- Cracka: "BK at a sushi restaurant....more devastating to the ocean than a BP oil spill...."
Big Kahuna is offline
post #7 of 86 (permalink) Old 10-02-2014, 04:09 PM
I am in for at least one set. Thanks Bill!
log1k is offline
post #8 of 86 (permalink) Old 10-02-2014, 08:34 PM
Dilbert 9C1's Avatar
If it includes bolts and washers then count me in... I had to hit the local yard to get a good bolt and washer ...
1995 Chevy Caprice 9C1 LT1 Former Saratoga Sheriffs Car
* Performance Mods- Gen 2 Tri Y Headers, Hi Flow Cats, Spin tech catback w x pipe, RAISS Intake, Rustic #750 Front Springs, Bilstien Shocks, UMI Rear Upper and Lower Control Arms, Dick Miller Racing Bars, Speed Tech Front Upper Control Arms, Factory 9c1 Front Sway Bar, HA Rear Sway Bar, 342 Gears w TruTrak Posi, PCMperformance Tune
* Visual- Slightly Cloned SS Parts-- Jerry Sequential tail lights--
Dilbert 9C1 is offline
post #9 of 86 (permalink) Old 10-03-2014, 05:25 AM
Bill I would be in for a set.
Thanks for getting this more attention. I hope it will run its course to completion. Interest fades quickly when parting with hard earned money.
Curtis
96 Impala BBB, 1.67 60', 12.31, (NA) Wrecked, but still lingering.ERE #17
96 Impala BBB, Lt4, 1.65 60', 12.35, (NA), #4450 race weight
96 DGGM Bone stock waiting for ERE transplant
Bigfoot2222 is offline
post #10 of 86 (permalink) Old 10-03-2014, 05:27 AM
96SSbbb's Avatar
Originally Posted by Dilbert 9C1 View Post
If it includes bolts and washers then count me in....
X2
ISSCA# 930
96SSbbb is offline
