Broken Window Roller Fix - Step by Step instructions - Chevy Impala SS Forum
 2Likes
post #1 of 194 (permalink) Old 10-25-2009, 09:42 PM Thread Starter
B-Body Builder's Avatar
Although this fix had been well documented before the crash, alot of forum members have been posting with complaints about the infamous "Broken Window Roller" problem. I decided to repost the entire fix process for those who have not done this fix on any of their windows before:
Note - You can save this entire webpage including pics to your PC for future reference with these steps:
1. Click "File" at the top of Internet Explorer, then "Save As" from the menu.
2. Next to "Save as Type" boxselect "Web Page Complete" in the menu, then "Save".
Problem - The Rear of your power window falls down out of the track or sags when the window rolls up (Could be on any of the 4 doors).
Solution - Replace both original "Rectangular" shaped window rollers with the newer style Round nylon rollers. It's nearly always the rear window slider that breaks, But If you really want to do this fix right, then replace BOTH Front and Rear sliders in the window track while the doorpad is off!!! Rarely does the 3rd regulator arm slider break in the lower track.
Parts for the fix:
(GM Parts)
(2) - 9666748 nylon Rollersand (4 or 5) - 10161510 Retainer Clips ( Door pad plugs for the Door Panel, depending on what door your fixing).
Optional roller source:
(2) - nylon rollers: Dorman part # 74444 from advanced auto parts or Rock Auto, NAPA.
(6) - 3/16" aluminum rivets OR (6) - 10-24 x 1/2" Bolts and (6) - 10-24 "Nylon Insert" locking nuts.
Tools for the project: (Will vary depending on What/How your doing the project).
5/16" Drill bit, 2" C-Clamp, Door pad plug tool, Small flat screwdriver, Short Stubby flat screwdriver, Phillips screwdriver, Channel lock pliers, Hand rivet gun, 3/8" open end wrench (Only for Nut/Bolt hardware method), Bearing grease, White spray lithium grease (Can) Blue painters tape and a magnet tool (Just in case).
For this example, I will be fixing Both sliders on the DS Rear door on my 95 Caprice. The process is similar on the other doors as well. Remember, These doorpads, armrests and switch panels are fragile......So take your time and go easy on them when removing them!
1. Remove the 2 screws that hold the armrest to the door, The gently lift the back of the armrest up a small amount and
pull out and remove it.
2. Remove the screw in the center of the doorhandle pocket (Behind the door handle). Then carefully insert a small flat screwdriver in either end of the pocket and press in on the clip that holds the pocket in, then pull out on the pocket until the clip clears the doorpad - repeat on the other end of the pocket, Lift the pocket out and over the door handle.
Door pocket clips on the ends
3. Remove the phillips screw in the doorpad at the bottom of the back end of the doorpad
4. Using a good doorpad plug tool, locate the doorpad plugs (In the doorpad pic). The gently pull out in an area close to rear of the doorpad, and pop out the 1st doorpad plug with the tool.....Repeat until all 4 doorpad plugs are removed from the door.
Now carefully grab the doorpad near the top on both ends and lift up on the Rear of the doorpad 1st until the inside seal comes out of the track, then lift up on the front end and gently work the doorpad up and out of the doorframe.
Remember, the Window switch still needs to be disconnected before the doorpad can be removed completly! Remove the electrical connector by pressing down on the light green tab, then pulling out on the Connector (Not the wire harness) to the window switch, whilke holding the switch in place in the doorpad. Now remove the doorpad.
Doorpad plug locations - DS Rear door (Other doors similar).
Electrical connector for the window switch
Cont....
"Da Factory Rat"
95 DCM Caprice LT1
B-Body Builder is offline
post #2 of 194 (permalink) Old 10-25-2009, 10:50 PM Thread Starter
Cont...
5. Now gently remove the plastic door paper from the inner door and set it aside. Remove the window switch from the doorpad itself, then temp hook the switch back up to the wire harness connector. Key in the On position, slowly lower the window until you can see the broken slider at the rear of the window track (Pic) thru the hole behind the armrest bracket.
Note: Step 5 also involves removing the arm rest bracket for greater access to the rear window roller area as explained below. This step is optional! Some people do it, some dont. If you dont intend to remove the armrest bracket....Skip to step 6
Stuff and old towel into the bottom of the inside of the door (To catch rivets and debris) and using a 5/16" drill bit.....Drill out just the center head of all 4 armrest bracket rivets, dont go any deeper - all you want to do here is just remove the rivet head. Gently tap out the rivets, then remove the bracket and set aside.
Broken rear slider (From a previous repair, you can see they used bolts/nuts instead of rivets in the ends of the window track for the repair)
6. In the pic above, Notice that the end of the track is crimped in slightly. These crimped in areas must be opened enough in order to get the old sliders out of the track, and the new round rollers in the track. Using a large flat stubby screwdriver, stick it in the rear of the track and pry open the crimped areas until the broken slider can be slid out and removed.
If you are replacing both front and rear sliders in the fix, then it is easier to drill out Both rivets in the ends of window slider track using a 5/16" drill bit, and removing the track from the window and door itself. Do this After you have uncrimped the rear of the track. You will have to slowly raise/lower the window in order to gain access to the rivets. My vehicle had been fixed in the past on this window so they used nuts and bolts in the track instead of rivets for the fix (Pic).
7. Once the 2 rivets have been drilled out of the track, Get a roll of the "Blue Painters Tape" and by hand, lift the window up from the inside and outside of the door until it reaches the top, then tape the top of the window to the door frame to hold it up. Better to use the blue tape (Comes off easier with no leftover adhesive).....I didn't have any on hand!
8. Now you'll see that the track is free of the window, and ready to be removed from the door, but 1st you need to pop the remaining good slider out off the ball stud at the front. Use your doorpad plug tool and carefully apply pressure to the slider until it pops out the ball stud (Pic). After closer inspection, My front slider had also already cracked in 1 spot, and needed to be replaced. Now guide the slider track out if the rear hole of the door.
9. Now get some bearing grease and apply a small amount to the center holes of the new round rollers, then using a 2" C-Clamp, carefully align the C-Clamp, roller and ball stud of the rear regulator arm up, and slowly tighten the C-Clamp down until the roller pops onto the ball stud.
10. Repeat the process on the Front ball stud. This one is a bit harder, but can be accessed by "Carefully" lifting the regulator arm with the window switch toward the top of the door until you align the access hole in the pic below. The clamp will need to be slid into the inside of the door, but it will fit and work. Paitence on this one!
Cont...
"Da Factory Rat"
95 DCM Caprice LT1
post #3 of 194 (permalink) Old 10-25-2009, 11:28 PM Thread Starter
Cont...
11. Remove the old sliders from the slider track, wipe the track clean of any debris and old grease. Get your grease again and apply a thin new layer to the inside of the slider track where the rollers go. This is also a good time to lubricate the regulator sprocket and scissors arms area where they cross, and also grease the lower scissors arm track where the 3rd window door slider rides in. Also a good time to spray some white grease lubricant into the lock arm connections, face lock and lock mechanism parts that are on this inside of the rear door while the doorpad is off! Any lock rods that were knocked off or adjustments needed to be made - Fix them now too!
12. Now insert your slider track back into the rear hole in the door, insert the rear round slider into the track, then guide the track thru the door and onto the front slider. If needed, the track Can be rotated to get both sliders onto it, but if you opened both crimped ends of the track, you wont have to do this.
13. Once the track is back onto both sliders, Carefully remove the Blue tape that hold the window up While holding the window in place so it wont fall! Now slowly lower the window until you can align the slider track back up with the holes in the window track. You'll likely have to slide the track L or R to line the holes up
14. Now this part of the fix is your option. You can use 3/16" aluminum rivets to re-attach the slider track to the the window frame, or you can use 10-24 x 1/2" Bolts and 10-24 "Nylon Insert" locking nuts for the job. I used the rivets because I prefer the more permanant fix (Cant come loose) effect of rivets but, the locking nuts should work too. The regular nuts on the prior fix on my door were starting to come loose when i did the job.....Locking nuts are a must here!
15. The rivets are kinda tough to get installed in the track, but I managed to get a hand riveter in both places in the door but Again, I had to "Slowly" adjust the window Up/Down to get the position just right to do it. Do the Rear hole 1st if you are using rivets on this fix.
Rear Rivet
Cont.....
"Da Factory Rat"
95 DCM Caprice LT1
post #4 of 194 (permalink) Old 10-26-2009, 12:07 AM Thread Starter
Cont....
Front Rivet
16. Once the Slider track is re-attached to the window frame at both ends, It's time to check your work and see if the new sliders are working and the window rolls up properly? If all is good, It's time to re-install the armrest bracket to the door. Again, you can use the 3/16" aluminum rivets or the 10-24 x 1/2" Bolts and 10-24 "Nylon Insert" locking nuts for the job.
It's your call. I again used the rivets.
17. Once the bracket is back on.....Carefully remove the Towel you stuck into the bottom of the door to catch debris (Or nuts the you dropped). Have a magnet or shop-vac handy in case you need it and DONT leave any metal in the door that can rattle around while your driving.
18. Now remove the window switch from the harness connector again. Time to re-apply the plastic door paper to the door. Personally I use a "Electric hot glue gun" and the clear glue, start at the top of the door and apply the whole top area 1st. It should be easy to tell where the plastic was before....just re-apply it. Once the top is in place, apply the rear area, then the front area. Now slide the electrical harness for the window switch thru the hole in the plastic, then glue the lower section down to the door
Note: Some people use tape rather than glue to re-apply the plastic......Again, it's your call but the glue works best and a more professional job IMO.
19. The rest of the fix is basically reverse order: Install the window switch back into the door pad, Make sure ALL the door pad plugs are Good and installed (I use all NEW plugs because they keep the door pad tight on the door). Also, make sure the deadner carpet is still fixed to the doorpad? If not, use the glue gun to stick it back on.
20. Get the doorpad close to the door, then hook the electrical connector to the window switch back onto the switch.
Carefully lift and tilt the top of the door pad window seal into the top door track, then install the pad back into the track, paying close attention that the doorpad is fitted down in both ends of the door.
21. Now align the doorpad plugs (1 at a time) and pop them back into their holes, then re-install the phillips screw at the rear of the doorpad.
22. Slide the door handle pocket back over the doorhandle, then pop the pocket back into the doorpad and re-install the phillips screw.
23. Re-Install the arm-rest and both phillips screws that hold it on.............Your done!
Note: The front doors and thr RS rear are nearly the same process as the LS Rear sliders, but once you've done 1 door with no problems, the others will be easier. Here's a couple of pics of the LF (Drivers) doorpad and doorframe for reference......I just started this fix this week!....
Drivers Side Door pad
Drivers Side Door
"Da Factory Rat"
95 DCM Caprice LT1
post #5 of 194 (permalink) Old 10-26-2009, 12:40 AM
snakey5138999's Avatar
Send a message via AIM to snakey5138999
I was all for your DIY until the taking off the arm rest part. Ive replaced these without have to take the arm rest out with a pair of vice grips, water boiled sliders and the right angling inside the door with the vice grips. Yours is probably more practical, but id rather save $20 on parts for a rivet gun and rivets. Ive done this like 5 times, so its easy for me lol...Its hurts your hand though, but its worth the sacrifice.
Chris Bobik
94 9C1 Caprice/Impala Clone Gone
2008 Impala SS
DD. Halo projectors, LED interior, 15% tint
95 BBB Impala
Performance RAISS Intake | Stainless Spintech Exhaust | CIA Tri-Y Headers| Eaton 4.10 Gears| Yank SS 3600 | UD/OD Pulleys
Exterior Clear corners | 12K HIDs | Shiny Stuff | 15% Tint |Suncoast Hood| Hotchkis Springs & Bilsteins | Smoothie Bumpers
Interior LED's | Billet Door Pulls
snakey5138999 is offline
post #6 of 194 (permalink) Old 10-26-2009, 01:03 AM Thread Starter
Originally Posted by snakey5138999 View Post
I was all for your DIY until the taking off the arm rest part. Yours is probably more practical, but id rather save $20 on parts for a rivet gun and rivets. Ive done this like 5 times, so its easy for me lol...Its hurts your hand though, but its worth the sacrifice.
You mean the "Arm Rest Bracket Part? Removing the arm rest bracket gives you more access to the rear section of the door, and also allows you easy access to lube the facelock and locking mech parts. Takes all of 5 min to drill 4 aluminum rivets out. If your fixing BOTH front and rear sliders, this is the easiest way to do it IMO. You can re-install the bracket with the 4 "Nuts/Bolts" combo above if it hurts the hands. Besides, shooting 4 rivets back into the arm rest bracket is childs play for me with one of these toys below in the garage... Too bad it wont reach the the slider track rivets too! .
Might want to be carefull with vice grips and soft boiled nylon, the teeth on those vise grips could scar the nylon or damage the roller while it's still soft???
"Da Factory Rat"
95 DCM Caprice LT1
post #7 of 194 (permalink) Old 10-26-2009, 03:43 PM
now you can soundproof
Great write up!
While your that far into the door, it might be the best time to apply dynamat etc.
Thanks for the info!
Bob Loblaw is offline
post #8 of 194 (permalink) Old 10-26-2009, 05:27 PM Thread Starter
Originally Posted by morbidly obese View Post
Great write up!
I did something similar to the dynamat on the front doors, just behind the door speaker locations. Yep, it's a good time to do that mod also!
"Da Factory Rat"
95 DCM Caprice LT1
post #9 of 194 (permalink) Old 10-26-2009, 06:16 PM
BYB_CUZ's Avatar
nice writeup, be careful with power window switch while your fingers are inbetween the scissor, my son hit the window switch and i almost lost a finger lol
09 G8 GT, lets just say modded
95 b4u- basically sold sadly
2009 jeep cherokee- sold
2014 grand cherokee
BYB_CUZ is offline
post #10 of 194 (permalink) Old 10-26-2009, 08:06 PM Thread Starter
Also, be very careful when working on DS front door sliders. The DS Switch has the "Express Down" feature for the drivers door. (The switch locks in when pushed in the down position and you dont have to hold the switch button to roll the window down). Always keep your hands out of the door when working Any of the window switches.......
"Da Factory Rat"
95 DCM Caprice LT1
