Rear Driver Side Door Wont Open. - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 05-29-2012, 03:13 PM Thread Starter
Walt718's Avatar
Exclamation Rear Driver Side Door Wont Open.
ok so i just got my 95 impala a couple of days ago and the only major issue it has is the door wont open from either the inside or out. I tried to remove the door panel to try and see what was wrong but you can only get it off so far with the door closed. And the size of my hands dont really help me out either. When I try to open it from the inside it feels restricted and only nudges a bit. On the outside it feels free as if there's no linkage attached?? HELP!!!!
btw this is my first post
Walt718 is offline
post #2 of 7 (permalink) Old 05-29-2012, 03:35 PM
SimplyTheBeSS's Avatar
does the door handle feel firm (Like the other doors) or does it feel limp? (That's what she said)
Only thing I could think of is.
*Door handle is broken
*Car got hit and bent something to put the door into a bind.
*Child safety lock switch got somehow messed up but should always let you open from the outside in.
1994 SS
SimplyTheBeSS is offline
post #3 of 7 (permalink) Old 05-29-2012, 04:08 PM
Or,it won't unlock. Try removing the lock bezel (gentle) manipulate the rod manually. Lock can bind so that the limited range of the mechanism isn't getting the job done on it own.Someone with long fingers,and a narrow wrist might be able to reach past the rods to the latch itself. Good Luck.
post #4 of 7 (permalink) Old 05-29-2012, 04:20 PM
that's a good point. I remember when I was putting my door panel back on that you had to get the manual door lock/unlock metal finger deal in there right or it wouldn't be right. I could see if someone screwed that up it could cause a problem where the door wouldn't lock/unlock.
1994 SS
post #5 of 7 (permalink) Old 05-29-2012, 04:27 PM Thread Starter
Walt718's Avatar
the outside handle feels limp. the inside handle feels restricted and only allows me to pull it about a 1/4 of the way out same as the rod when i took the panel off. it felt as if it was jammed onto something but as far as me seeing or feeling that was a no go because it wasn't in reach or sight.
Walt718 is offline
post #6 of 7 (permalink) Old 05-29-2012, 04:33 PM Thread Starter
Walt718's Avatar
the car wasnt ever in an accident to my knowledge. it was originally my fathers for 6 years before he gave it to me. and the door wont open. it locks and unlocks fine i assure that when i took the panel off.
Walt718 is offline
post #7 of 7 (permalink) Old 05-29-2012, 10:33 PM
coldsteelmike's Avatar
Location: Jacksonville, FL, U.S.A., Earth, Milky Way, Universe
^^^This.
-Mike
"...So let me first assert my firm belief, that the only thing we have to fear is fear itself."
-Cracka Ass Crackah (1933)
coldsteelmike is offline
