Grant Steering Wheel Installation Tips - Chevy Impala SS Forum
post #1 of 29 (permalink) Old 07-06-2013, 09:38 PM Thread Starter
sonuvah's Avatar
What follows is an outlined sequential explanation with pictures of the steps I took to remove and install a new aftermarket steering wheel - the Grant Elite GT 742. Much of what is written here was not fully explained in the Haynes manual or other posts that I could find as it’s specific to the Grant Steering wheel application.
I followed instructions from a Haynes manual for the steps of stock steering wheel removal so I will not include that part here. The direction pages that are included with the new adapter and steering wheel are worth looking at, but were not specific enough for the ’96 Impala application. Some parts were not used and directions became confusing. However, the exploded views did give a general idea of how the new unit is pieced together.
1. Park car so steering wheel is in the straight ahead position and ignition key in lock position. Disconnect negative battery cable.
2. Allow for several hours and even multiple removals and reinstalls of the new steering wheel as this may be necessary to get just the right spacing of the adapter on the steering shaft and deburring amount of the inner lip of the steering column for an acceptable smooth rotation. 2 different steering wheel pullers will be needed, one with the straight beam, center anchor screw and the 2 long fastening screws to be used for removing the stock wheel. The other is the 3 prong puller used for pulling off the new adapter (which will probably be needed if/when the new wheel is tightened down too much which creates binding of the unit). Both were “rented” at Autozone. It’s a trial and error process to get just the right spacing for the new bezel (post cover) and the adapter on the splined portion of the steering shaft so that there is maximum engagement, but also without binding which will make the wheel very difficult to turn. You want to get the post cover bezel (half bagel shaped black piece) inserted just inside the lip of the steering column bezel (about 1/8”), but not too much so the wheel rotates smoothly. I also put some bearing grease along the rim of the inner lip to promote smooth rotation.
3. The yellow air bag wire needs to come out by disconnecting it from its mate at the bottom under the dash, cutting off the connector end, and then pulling it out through the top with the removal of the clockspring. The small hole next to the yellow wire on the left is for the horn wire, which has been removed in the picture. I used the new horn wire and spring included with the Grant steering wheel, but used the stock black plastic tube retainer to install it as the white Grant retainer tube was too tall. I also needed to cut the black tube retainer in half as that one was also too tall once the new adapter was installed. Make sure to leave one of the little nipple tabs intact so it will engage in its slot and maintain proper position. (Sorry, I don’t have a picture of the horn wire piece).
4. Used a drill with a sanding barrel piece to remove the two tabs at the top of the steering column, which were there to hold clockspring in place. Also deburred/sanded the entire circumference of the inner lip of the steering column as the post cover bezel was just too tight of a fit and made the steering wheel very difficult to turn. This may have to be done several times to get it to an acceptable tolerance of turning resistance/smoothness. It took me 3 times to get it to a comfortable amount of free rotation – not too stiff. Be careful not to sand too much and compromise the integrity of the steering column outer housing.
5. Next, install the adapter onto the steering shaft by using the steering shaft nut (13/16” socket). First time, I tightened it all the way down and that was too much as the post cover bezel which attaches to the adapter was too far into the steering column – too tight. So needed to use the 3 prong puller to pull off the adapter and try it again to get the right depth for the post cover bezel. Finally settled on adapter top flat being about 1/8” above splined portion of shaft. This is about 98% engagement and very safe, I believe. This will prevent any washers from having to be used to create more space when the post cover bezel is attached in the next step. The bearing grease can be seen along the inner lip in the picture. This will help to give an accurate assessment of how the wheel will feel in its rotation when assembled. Also, see the horn wire coming thru the adapter at top. The adapter will need to be positioned onto the splined portion of the steering shaft just right so the steering wheel is at the straight ahead position, while at the same time allowing for the 5 steering wheel attachment holes and the horn hole on the (black)spacer to be lined up properly and in the straight ahead position also. This should make a lot more sense and be clear when the 3 pieces are put together to achieve alignment. Once correct position of the adapter is achieved, remove the steering shaft nut.
6. Install steering post cover bezel onto the adapter with 3 screw holes and horn holes matching. How is the insertion depth into the steering column? Hopefully,not too much. About 1/8” is good. If it’s more you may need to back off the adapter a little more.
7. Next, attach spacer to steering post bezel cover and adapter with 3 screws provided (use blue locktite), matching horn holes again.
8. Next, install steering shaft nut, not too tight to cause binding. When it just makes contact with spacer surface, just a tiny bit more tightening to achieve snug position (use blue locktite). I did not use a torque wrench, just feel.
9. Next, install steering wheel in straight ahead position. Insert key and unlock. Test steering wheel rotation. If it’s too stiff, the entire unit will need to be removed again and process done again to get the right adapter spacing and/or smoothness of inner column bezel. Note the steering shaft nut top surface is just below the steering shaft, about 2 threads on shaft are showing.
10. Once good rotation is achieved, the horn button can be inserted. Connect the wire to the center tab on the back of the button first.
11. Next, move on to the yellow air bag wire at bottom of dash. Inside the yellow outer sheath are a green and white wire. Install a 2 ohm, 10 watt resistor between them. Use 2 wire connectors with heat shrink sleeves to do so.
This should do it. Connect negative battery cable. Air bag light should go off after a few blinks. Enjoy.
Parts:
http://www.streetsideauto.com/search...ords=grant+742 ($127)
http://www.summitracing.com/search?k...el%20742&dds=1 ($146)
Adapter kit - 5 Hole Billet Steering Wheel adapter 69-94 GM Chevy, 76-95 Jeep in BLACK
http://www.ebay.com/itm/261184071807...#ht_3310wt_932 ($42)
Resistor:
2 ohm, 10 watt
local electronic parts store ($1.60)
2 wire connectors with heat shrink insulation cover
Ace Hardware ($1. 69)
This adapter kit piece is not used:
"Monk in Training"
sonuvah is offline
post #2 of 29 (permalink) Old 07-07-2013, 09:25 AM
Very nice.
Thanks for posting up....this will be one of my next projects.
post #3 of 29 (permalink) Old 07-07-2013, 10:31 AM
Nice install write up. I didn't need to do any clearancing of the column though.The "742" is one of the most attractive wheels Grant offers,in my opinion.
quickest event reaction time .017sec. (final-round)
1slow96 is online now
post #4 of 29 (permalink) Old 07-08-2013, 10:24 AM Thread Starter
sonuvah's Avatar
Thanks, guys. There were several "Mr. Magoo moments" during this project. Vanquish the gremlins!
"Monk in Training"
sonuvah is offline
post #5 of 29 (permalink) Old 07-08-2013, 01:56 PM
The Lazy Destroyer's Avatar
Great post. I agree the 742 looks sweet.
I just installed my wheel (the basic Grant 701). My bezel cover rubs on the steering column a little bit, I have to go back and try to re-install or worst case file off 1mm on either the bezel cover or the column plastic.
But overall an easy installation. I may pick up another wheel in the future with a more rubber/softer wheel grip, but the 701 works for now.
-Blake
________Motoception Photography________
"Those who possess power define those who are powerless."
95 Caprice 9C1, 12.9 @ 103 mph, 1.74 60' - Bolt-ons car
96 Caprice Wagon - "Nomad SS"
94 RMW woody
The Lazy Destroyer is offline
post #6 of 29 (permalink) Old 01-24-2014, 04:47 PM
where do you wire the resistor in? just into the original harness? one on the green, one the yellow? can you just plug it into the harness or do you have to wire it in?
Daniel, a 19 year old with a chevy obsession
1995 Caprice Classic Wagon- 205,000 miles, almost completely stock, trying to restore before upgrading
2001 Kawasaki Zr7s- 30,000 miles, crashed by me, rebuilt, designed, customized by me, halo headlight, d&d exhaust, custom paint, renthal bars, air box mod on the way
Dkrems123 is offline
post #7 of 29 (permalink) Old 01-24-2014, 05:50 PM
Obviously,a variety of methods can be used. I decided to solder the resistor(s) to the wires coming from the dash harness.
post #8 of 29 (permalink) Old 01-24-2014, 08:55 PM
I've written this installation process up a couple of times, and it is nice to see it in pictures. The Nardi and MOMO wheels install the same way with a suitable adapter. One is sold by apple289 and another is NRG. Both are available on ebay.
The one from apple289 needs a modification to the horn wire hole. The hole is about 1 diameter too far clockwise, and must be cut to allow for proper installation. The unit is made almost exactly the same as the Grant, but has a dual 6 hole pattern. You can get it with a 5/6 hole adapter as well. The adapter is available in different heights, and the 1 inch is the proper height for the B-body installation.
The NRG does not go inside of the trim, and is a little easier to install, because it is a one piece unit. You can get the NRG in a slimline, and put a quick disconnect between it and the wheel. There is a very inexpensive quick disconnect, that with a small modification, some custom length screws, and a 10mm spacer makes a clean, tight installation.
If you have a quick disconnect, you have an automatic security system. If you feel like there is a chance your car might be stolen, take the steering wheel with you. The cars are really difficult to drive without the steering wheel. A thief will walk away to another easier mark.
Name:	white elephant int.jpg
ID:	71834   Click image for larger version
Name:	momo wheel.jpg
ID:	71842   Click image for larger version
Name:	Starship new shift knob.jpg
1991 OCC 461 (.030 over 454) BBC, 3.23 posi, flash to pass, drop spindles & springs, Impala rims, Recaros, MOMO/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...sed-parts.html
post #9 of 29 (permalink) Old 02-17-2014, 12:50 AM
coltonx3's Avatar
my horn just goes off when i put the screen
95 9c1 dggm
straight black pvc kn filter
spintech pro street mufflers
most of trim and grill painted black
150k running strong and going
coltonx3 is offline
post #10 of 29 (permalink) Old 02-17-2014, 01:26 PM
Great write up! My only suggestion to your instructions would be to have another person hold a shop vac to the area being sanded down in order to prevent debris from falling into the inner column and contaminating the the bearings and electrical components.
Steve
Black 1996 SS, lot's of mods, sold 3/24/14
killian96ss is offline
