Cost to have Trans. rebuilt???????????????? - Chevy Impala SS Forum
post #1 of 15 (permalink) Old 03-16-2017, 03:25 PM Thread Starter
How much have you paid? 1995 wagon LT1 engineOldh ead
95 WAGON.SS wheels,Exhaust straight out the back.Extra bright cargo lights.Virgin ashtrays,Copper battery term.32# in tires
oldhead is offline
post #2 of 15 (permalink) Old 03-16-2017, 04:44 PM
juniorwatson's Avatar
Where are you located. There's two reputable rebuilders on this board. One is Mike Harris around the Cleveland area, and Cahall Performance Transmissions in the Maryland area if memory serves me correctly.
I bought one from Mike in the late fall of last year for $1,400.
You can contact Mike @:Mike Harris
Cahill's home page: CPT
Both guys were great about giving information about what they offer & recommend.
I had no bias toward either and I chose Mike because he was on the route from Central, PA to Austin, TX, when my parents finished putting my grandmother's house on the market. I had no shipping costs, so that drove to use Mike.
Clear Image Tri-Ys & Hi-Flow cats to CIA 2.5" X-Pipe & Spintech Mufflers, Mike Harris 4L60E, Vigilante 3,400 RPM Converter, MOOG FT end, Del-A-Lum bushings in new MOOG CTRL Arms, Eibach FT Springs, New Stock rears. Hotchkis Sway Bars & End Links, RAISS, Dynoshaft, CIA Driveshaft Loop, BMR Trailing Arms, Braided Brake Hoses, Taylor Spiro-Pro Wires, AutoMeter 2-5/8" Water Temp & Oil PSI Gauges, Impala Console. ATE Blue Brake Fluid. Skip White distributor. Newly Installed 20's on 1/1/2017
juniorwatson is offline
post #3 of 15 (permalink) Old 03-16-2017, 08:03 PM
Moby Dick's Avatar
Send a message via AIM to Moby Dick Send a message via Yahoo to Moby Dick
Cahall...right.
Mine lasted less than 1500 miles. Run away.
Eric Seaman
1994 Caprice Wagon "Moby Dick"
1996 Impala SS 383 11.604@117 CC503 with 3.73's.
1.52 60' on drag radials
"Fastest NA 383 3.73 equipped car on the board"
ISSCA Member #2517
Moby Dick is offline
post #4 of 15 (permalink) Old 03-16-2017, 08:26 PM
Put your zip in your location, so we know where you are.
I paid $1300 for a heavy duty trans plus $500 for a Circle D torque converter. I installed them myself behind a 454. Depending on how bullet proof you want it, anywhere between $750 and $4000 plus installation, or shipping.
post #5 of 15 (permalink) Old 03-16-2017, 10:42 PM
capriceutah's Avatar
just go 80e. A stock 80e is stronger than a built 60e
95 Caprice Wagon 100 K daily driver.
72 Chevy C10 1/2 ton longbed parts hauler-Sold
72 Buick Skylark 350 56K-Rollin Cragar SS's now Buick 455 in the engine bay,
capriceutah is offline
post #6 of 15 (permalink) Old 03-17-2017, 07:44 AM
Trans
I paid $850 for the rebuild on my 95 Wagon. Local guy in SE Michigan. I pulled the trans and gave it to him.
Ken
Ken Hennessy is offline
post #7 of 15 (permalink) Old 03-17-2017, 01:07 PM
fuzzcar's Avatar
I rebuilt one myself with very mild upgrades (really just a corvette servo and some others that do not require any additional parts) and the parts alone were 6-700 and I did not even replace every part that the performance builders recommend you replace every time.
fuzzcar is offline
post #8 of 15 (permalink) Old 03-18-2017, 02:30 PM
TGO
Your location is also important but I think I paid about $2800.
Stock rebuild would have been cheaper but decided to do a little strengthening to avoid having the same problem down the road.
TGO is offline
post #9 of 15 (permalink) Old 03-18-2017, 07:15 PM
k gee's Avatar
$1200 in Los Angeles for someone to do ALL of the work and beef it up slightly(better sun shell, Transgo kit)
96 DCM Caprice B4U
96 RMW Collector's Edition *Sold*
www.cali-ss.com
k gee is offline
post #10 of 15 (permalink) Old 03-18-2017, 09:19 PM
gbhs72's Avatar
I'll refer you back to this post I did awhile back. I have NOT used them so check and be sure they offer what you want. https://lawton.craigslist.org/pts/5975271734.html
Not knowing where you're located I'm not sure what the shipping would be.
Mark: Snowman-33
93 9C1: Work
gbhs72 is offline
