Comments, corrections and suggestions are welcomed. No questions please.
Last updated 12/16/2023
A what-body? - refers to the GM vehicle "platform": (relevant years are included)
B-body: Chevy Caprice, Buick Roadmaster, Olds Custom Cruiser (1991-1996)
D-body: Cadillac Fleetwood (1993-1996)
F-Body: Camaro & Firebird (1993-2002)
Y-Body: Corvette (1992-1996)
Can I use a 4L60 or 700R4? from a '91-93 Caprice or other vehicle?
Don't bother. You could, but it's not worth the effort. The internal rotating parts are basically identical but everything else is different. Sell it and get a 4L60E.
Note that the 4L60E was introduced in 1993 on the full size trucks, and '94 on everything else. The 4L60 (non-E) is controlled very differently and is very difficult to swap in.
4L60E similarities:
All 4L60E/4L60/700R4 have the same gear ratios from the factory.
1 - 3.06:1
2 - 1.63:1
3 - 1.00:1
4 - 0.70:1
There is a Sonnax 77284-K aftermarket gearset available which reduces 1st and 2nd to 2:84:1 and 1.55:1; it is ~$700.
Are LT1 sedans and wagons the same?
Yes. All '94-96 wagons came with LT1s standard.
What about '94-96 Impala SSs vs. 9C1s vs. civilian cars?
If they had the LT1 engine, they're all the same.
GM B and D-body 4L60E differences by year:
’94: First year of electronic controls in the valvebody (versus the ’93 4L60, which did not have this). The PCM controls line pressure (holding power and shift feel), 1-2, 2-3 and 3-4 upshift and downshift points (based on vehicle speed), and TCC lockup (timing, and in the ’95-up models, apply feel). Everything else is done mechanically/hydraulically.
’95: Added a Pulse-Width Modulated (PWM) Torque Converter Clutch (TCC) apply solenoid to control the feel of the TC clutch lockup (blamed for many 4L60E problems; TransGo HD2-C bypasses this, but best to have a shop install the Sonnax 77754-03K valve, or 04K if you are 97'-up). Also changed 3-2 downshift solenoid mid-year (see '96, below).
’96: PWM TCC plus a different tailhousing design with new-style Vehicle Speed Sensor (VSS) on the passenger side. Also changed the 3-2 downshift solenoid in mid-1995 from PWM to on-off. There was a new manual valve added along with a relief port over the manual valve on the valve body casting with this change. This solved the low/reverse clutch release problem and makes the TransGo manual valve mod unnecessary (see ATRA bulleting 2002-46).
How do I tell if this transmission came out of a Caprice/Impala/Roadmaster/Fleetwood?
GM modified the cases for catalytic converter clearance. There were two mounting ears at the front that GM left in place on trucks and Corvettes; you'll need to cut these off flush to put them into your car. NOTE - these casting don't have the same bolt holes for the torque converter cover that ours do; you may need to drill and tap your own. '95 Corvette 4L60E for reference:
How to visually tell B and D-body transmissions apart by year:
'94: VSS on driver's side of tailshaft housing, and when you remove the torque converter, there is no "PWM" on the front surface of the pump. In the pan, only one solenoid on the front face (relative to the transmission in the car) of the valvebody. Inside of the wiring connector is purple.
'95: VSS on driver's side of tailshaft housing, and when you remove the torque converter, there is "PWM" in raised letters on the front surface of the pump. In the pan, there are two solenoids on the front face (relative to the transmission in the car) of the valvebody. Inside of the wiring connector is green.
'96: VSS on passenger side of tailshaft housing, and when you remove the torque converter, there is "PWM" in raised letters on the front surface of the pump, and around the outside of the pump there are raised ridges. In the pan, there are two solenoids on the front face (relative to the transmission in the car) of the valvebody. There will be two brackets on the top rear of the case for the rear O2 sensor wiring. Inside of the wiring connector is green.
9C1 Trans differences:
9C1 4L60Es come with a “1st gear lockout” function that is a tab secured next to the shift linkage by the oil pan bolts. This can be removed by removing the two bolts and then reinstalling and torqueing them to 9ftlbs. Note 2022 - this tab is now extremely rare. If you find one, hang on to it.
LT1 vs. L99 Trans differences:
4L60Es in L99 4.3L V8 cars come with a smaller servo than the LT1 5.7L V8 cars, which come with the cor-“vette” servo (part number ends in 093) for more holding power on the 1-2 and 3-4 shifts. If an L99 4L60E is going behind an LT1 engine, the servo assembly should be swapped over before installation (easily accessible on the passenger-side of the case, but you'll need a new servo o-ring seal). You can get one from Ebay, TransGo or Sonnax 77701-04k, or you can get one on Ebay.This materially shamefully stolen from ImpalaSSForum.com, authored by Sherlock9c1. Also, the boost valve is smaller (again, Transgo and Sonnax sell boost valves), and it is possible that some holes in the separator plate are smaller. While we're talking servos, Sonnax and others make larger ratio servo pistons for both 2nd and 4th gear. There may be some minor differences inside the valvebody in the springs.
Cadillac Fleetwood V4P differences:
Cadillac spec'd the Fleetwood towing package (V4P) to tow up to 7000lbs. The transmission was factory setup to shift a bit firmer. If you swap one of these transmissions into your car, be careful how much line pressure you add in via the PCM. Each vehicle and package generally had some small tweaks (L99 vs. LT1, truck vs. car), so be aware that the shift feel will probably not feel the same after a swap.
Can I use a 4L60E from a...?
Note: This info assumes you can swap or remove cooler line fittings, electronics modules, tailshaft housings, and shifter brackets yourself.
Note: 4x4 vehicles have a shorter and different output shaft which cannot be swapped without partially disassembling the transmission. It's a relatively quick procedure for someone who knows how to do it (like a local shop) and only snapring pliers are required, but it's not for the novice.
1. CK Truck or Fullsize Van: Any case with a "K" casting in the upper passenger side out of a '94-97 GM full-size 2WD pickup will work. 4WD transmissions have shorter tailshafts which cannot be swapped without disassembling the transmission. 4L60Es behind the 305 V8 and 4.3 V6 came with the smaller '..553' servo which should be replaced with an '..093' "corvette" servo. This materially shamefully stolen from ImpalaSSForum.com, authored by Sherlock9c1. Other V6 versus V8 internal differences are unknown. Using 4L60Es from LS-engined trucks will probably encounter the same issues as ones from LS1 camaros (see below).
2. S10/Blazer (2WD 4.3L V6 only): Probably. 4L60E was used '93 up to '96???. You will need to swap the servo assembly out of your b-body 4L60E (make sure to put a new blue o-ring on the servo cover). You will have to swap the longer shift shaft assembly with electronics for the shorter B-body one without electronics. Other mounting, electrical and internal differences are unknown at this time.
3. F-body (Camaro-Firebird) LT1 4L60Es from '94-97 will fit. They also have the "corvette" servo.
3b. LS 4L60Es from '98 up will NOT work without swapping the input shaft to the earlier style, which requires partially disassembling the transmission. The LS 4L60E converter sticks out 10mm farther forward than the LT1 ones do.
3c. V6 (3.4L and 3.8L) transmissions have incompatible bellhousings and will not work.
4. Corvette 4L60Es from '94-96 are identical internally (and obviously have the "corvette" servo). The case will need to be modified to remove the ears on the bellhousing and bolt the exhaust hanger bracket to the vette case.
5. 2001-up GM 4L60E/4L65E powertrains added an input shaft speed sensor on the backside of the pump that allows the PCM to monitor and control converter slippage. You can use control one of these newer units with an LT1 PCM as it doesn't care about that sensor. I don't think it's true the other way around.
What's the differences between a 2WD and a 4WD 4L60E?
The tailshaft housings are different (easy swap). The output shafts are longer or shorter (4WD) (not so easy). The transmission pump and input assembly must be removed to get to the snapring. It's an easy job for a transmission shop, but not for the novice.
Can I use my stock 4L60E behind an LS motor?
YES! - there are adapter flexplates you can buy.
More discussion here.
Caprice Transmissions from '8x-96:
198?-1990 - 700R4 (also 200-4R on some models)
1991-1993: 4L60
1994 - on : 4L60E
4L60E similarities:
1 - 3.06:1
2 - 1.63:1
3 - 1.00:1
4 - 0.70:1
1991-1993: 4L60
1994 - on : 4L60E
