Wondering whether you should flush your trans if you don't know its history? Read this first.
Updated 7/16/2020: TL;DR / Bottom Line Up Front:
Disconnect one of the trans cooler lines near the battery. Put a clear 3/8" hose on the hard line (need maybe 2 feet of it) and then start the car to pump out the pan. Shut off when it stops flowing. It won't hurt the transmission to suck air for a few seconds.
Drop and clean the pan and magnet, replace the filter, reinstall the pan. Torque is 8 ftlbs, don't overtorque.
Refill transmission with new fluid (the same amount that first pumped out).
Then repeat the flush procedure until the fluid in the clear hose turns color (you'll see it, usually by 10.5 quarts). Use clean empty gallon milk jugs to catch several quarts each time. Check the dipstick regularly every 50 miles to see if the new fluid picks up more grit. If it does, flush it again. If the fluid stays clean, you're done.
Detailed steps:
Jack up the car, EDIT - unless your car is lowered, you likely don't have to jack it up. Just get to a point where you can reach the hoses below. You can avoid jacking the car if you can slide a pan underneath to catch the fluid.
Disconnect the cooler line at the one joint near the battery where there's a hose clamp.
Put a short length of tubing on the hard line, and aim it into a bucket or a pan that holds at least 4 quarts if you have a stock pan, or 6 quarts (1.5 gallons) if you have a deep pan. Don't worry, no fluid will come out of the rubber hose you disconnected. I'm now using milk jugs as catch cans with the stock trans pan and have never overfilled one yet.
Start the car.
The engine running will drive the transmission pump, which will pump all of the fluid out of the pan for you.
When the flow out of the hose starts to sputter, shut the car off so you don't damage the pump.
If you're OCD, wait a minute for any residual fluid to drain into the pan so it can get to the filter, then run the car a few more seconds. You should be able to get around 3-4 quarts of fluid out using this method.
Now, the pan will be nearly empty (maybe 1 qt remaining in the pan) and you can change the filter and clean the pan if you want to. If you find metal chips or chunks in the pan, start saving for a rebuild. Dust is ok.
Measure how much you pumped out, refill the same amount of new fluid back into the transmission.
Repeat steps 4-9 until the fluid color changes to the new fluid.
Now your transmission is flushed out.
A 4L60E transmission, a stock-diameter (12") torque converter, and alll of the assorted cooler lines and coolers holds 11 quarts. You will not be able to pump all of this out in one shot - the pump will drain the pan dry and you will have to add 4-5 quarts of new fluid, then continue pumping until the fluid coming out of the cooler line changes color. It will be visibly obvious. I started seeing clean fluid come out of the hose at around 8 quarts after having cleaned the pan and installing a new filter.
If you want to flush out your cooler lines while the transmission is out of the car, go buy a can of Kooler Kleen or equivalent from Napa and blow the lines out both ways, then finish off with compressed air. Do this ESPECIALLY after you've had any sort of failure in the transmission, whether a worn-out 3-4 clutchpack or a hard part failure.
I have used this method for the past 4 years, and it is the way to go. I normally un do the lower cooler line at the rediator. But that is a slight difference.
Works great! No more fighting the fluid flilled pan on your back.
Am I the only one with a bolt in my tranny pan? Just like oil for me, I unscrew let it drain then take down the empty pan... Was this bolt just added on by previous owner maybe?
This convenient oil-based solvent saves time and money for general service and repair shops. It will prevent contaminating new or rebuilt transmissions you install. The flush can is used to prevent transmission contamination by removing and eliminating contaminants such as grease, dirt, sludge, grime and metal shavings in transmission cooling systems and lines, without leaving any water or soapy residue in the system. It also cleans electric parts, wire harnesses, etc. leaving a thin layer of dielectric protectant.
Put a short length of tubing on the hard line, and aim it into a bucket.
Have a friend start the car.
Wait a minute for any residual fluid to drain into the pan, then run the car a few more seconds.
Now, the pan will be empty and you can change the filter if you want to.
I just wanted to say thanks for this info! I did steps 1-9 to do a filter change. Man did that avoid a mess. I had a little trouble coaxing the rubber cooler line off the hard line, but patience prevailed.
There was a little fluid left in the pan when I dropped it, but I took my time bringing it down so no problems there. The only mess was from the drips coming off the internals of the trans once the pan was off, but I had some cardboard underneath to catch the drips.
FYI to all: This is linked from the Links thread at the top of this section.
I would also recommend you change your fluid at least yearly. The detergents in Automatic Transmission Fluid (ATF) tend to hold dirt and gunk in suspension (until there's so much that it overwhelms the detergents and falls to the bottom of the pan). The best way to get that out is to completely flush your fluid each year. It's way cheaper than a rebuild.
Wear old clothes, because they will be permanently stained. I put a big piece of cardboard under the car to catch the drips, because they just kept falling.
Loosen all the bolts holding the pan to the transmission. There will still be a little fluid in the pan, so hold it level as you take out the last couple of bolts.
The following is courtesy of Gregg Nader of Sonnax:
Note that GM has pulled the licenses for Dexron 3 / Mercon because companies were using base stocks for the additive packages that were not meeting spec over the long term. That's why you can only find names like "DexMerc3." The fluid is still suitable for the 4L60E.
If you can find synthetic fluid, you will get a much longer time until viscosity breakdown.
The pump will empty the pan and start to sputter as it sucks air. Shut the engine off immediately once this happens so you don't damage the pump. The total amount of fluid pumped out during this process when I was flushing my wagon was around 4 quarts. I went back and updated the post a bit to make it clearer.
So, the total capacity of the transmission, torque converter, and cooler lines is 11 quarts. You won't get all of that out in one shot. You will need to pump out the pan, add another 4 quarts, and repeat until you have run at least 10 quarts through (that's what I saw in my case). You can literally see the fluid coming out of the drain hose change color and become transparent. I did this at night with a droplight hanging next to the drain hose and the color change was obvious.
ok so drain till sputter, then add new fluid 4 quarts then drain till sputter, and repeat till fresh color fluid. you said pass about 10 quarts through do i just add the fluid thats fresh back the bucket into the tranny? and add the remaining quarts? at which point should i change the filter? sorry im a lil slow this is a first time for me i would rather mess up my own car than have the dude that told me i only needed 6 quarts lol. i guess not all mechanics know everything
Don't bother trying to save the new fluid that comes out of that hose. It's just a part of the flush process that you will end up blowing out some good fluid while chasing the bad fluid. It's $3-$6 worth of fluid lost to do a flush that most shops will charge you $150 or so.
Just changed the filter an toped it off, next went down to my local trans shop, that I've seen sense 97 (1,2,3) three of them they all had the machine but refused to service due to I had my own 24 quarts of AMSOIL, As I read over the Technical Bulentin it noted to refill from dip stick while vehicle is running. As the other line is off at the cooler...
If the upper line at the radiator is the one going to the cooler, the bottom one would be the return line correct? Why cant you run two lines one to a empty bucket(upper) one to a full bucket (lower) an start the car.
Or is it better to drain an fill as noted in this tread??????
I was wondering from the photo it looks like the orginal fittings was cut out an replaced with Transmission hose.(mine still have orginal compressed line) If I undid the lower hard line to the radiator I still have to fill at the dip stick to the pan correct. Would it be better to undo both lines and have a empty bucke for the cooler line, an a filled bucket with tthe return line????
I was under the impression that it's the fluid in the return line that cools,and lubricates all the bushings,and thrust surfaces inside the transmission before it dumps to the pan. If so,doesn't this method risk starving these critical parts of fluid.
Related Threads
Chevy Impala SS Forum
1.9M posts
42.8K members
Since 2000
