Car will not shift out of park ? - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 12-30-2009, 09:15 AM Thread Starter
usedtobeafordguy's Avatar
My 96 Caprice is stuck in park. I can barely move the shifter. Where do I start? I'm pretty baffled and hoping has something to do with it being 11 degrees out last night. Any help is appreciated.
95 Caprice wagon DCM
ISSCA # 2424
usedtobeafordguy is offline
post #2 of 8 (permalink) Old 12-30-2009, 09:58 AM
1FAST94's Avatar
Sounds like water has gotten into the cable and frozen. Don't force it and break that cable: you can't buy them.
Mike Harris
B-BODY PERFORMANCE
Dayton, Ohio
10.43 @126.95 @ 3800 lbs.
http://www.youtube.com/watch?feature...&v=a8dYCl2cAdM
1FAST94 is offline
post #3 of 8 (permalink) Old 12-30-2009, 10:22 AM
Send a message via AIM to bigblock671
check to see if your brake lites are working the shift interlock circuit feeds off it
350 musi alum heads 503 cam 11.93 1.62 60@112 n/a 11.50 @115 1.52 60 100 shot
bigblock671 is offline
post #4 of 8 (permalink) Old 12-30-2009, 03:42 PM Thread Starter
This was it. I wasn't sure about the brake lights until I went back to check it out with my wife this morning. I wiggled the stop light switch and was able to shift again and get the car home. My brake lights are still intermittent, so I guess I have to check the switch again. Thanks everyone for the help.
ISSCA # 2424
post #5 of 8 (permalink) Old 12-31-2009, 05:22 AM
MrBuick (Magnum)'s Avatar
Send a message via AIM to MrBuick (Magnum)
Seems to be a decently common issue on the B-body line. The brake light switch fails. But typically, it will fail so the brakes are always on. I would just replace the switch. It was about $15 last time I replaced one. One of my cars has a hidden switch, that makes is so the shift lever can't be moved even when you press on the brakes. My dad sat there for a few minutes when I armed it, and forgot to tell him about it. "WTF is wrong with your car, Cory!!"
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS. 14.21 at 91.79 "Jesus", Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.12 Buffman's car, Cracked Piston at 180k
96 DGGM Buick RMW 263k Stock Tranny
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi, and the rest of the Bolt-ons. Fried #7 Ring.
And 5 other LT1 B-body's... Is there Rehab for this Sh*t?
MrBuick (Magnum) is offline
post #6 of 8 (permalink) Old 12-31-2009, 09:40 AM
Buffman's Avatar
Send a message via AIM to Buffman
It's like $9 or was from RMS. get one, and you'll be happy. Mine used to be messed up where it would let you move it in and out of park with no brake.
Matt Hoffman
Exhaust Video Burnout!! New Quick Video!
ET: 13.5272 @99.33mph 1.82 60'
^^ Gone 7/12/09, but not forgotten
Buffman is offline
post #7 of 8 (permalink) Old 12-31-2009, 11:25 AM Thread Starter
Thanks everyone. If it's that cheap, I'll just get a new one and stop messing with the old one.
ISSCA # 2424
post #8 of 8 (permalink) Old 01-02-2010, 08:41 PM
personally i remove the shift interlock on my cars but thats my preference
