1991-1996 caprice/impala Gears - Chevy Impala SS Forum
post #1 of 32 (permalink) Old 09-05-2010, 03:09 PM Thread Starter
fullname's Avatar
"8.5" 10 Bolt 30 Spline Ring Gear Axle
GM8 - 2.56
GU2 - 2.73
GU3 - 2.93
GU4 - 3.08
GU5 - 3.23
GU6 - 3.42
G80= Positraction
1991 - L03 Caprice(5.0) 2.56Gears
1991 - L03 Caprice Wagon(5.0) 2.73Gears
1991 - L05 Caprice 9c1(5.7) 3.42Gears
1992 - L03 Caprice(5.0) 2.56Gears or (0ptional 3.08) or (LTZ 3.23)
1992 - L05 Caprice Wagon(5.7) 3.23Gears
1992 - L05 Caprice 9c1(5.7) 3.42Gears
1993 - L03 Caprice(5.0) 2.56Gears or (0ptional 3.08) or (LTZ 3.23)
1993 - L05 Caprice(5.7) 3.23Gears
1993 - L05 Caprice 9c1(5.7) 3.42Gears
1994 - L99 Caprice(4.3) 2.73Gears
1994 - L99 Caprice 9c1(4.3) 3.23Gears
1994 - L99 Caprice Wagon(4.3) 2.93Gears
1994 - Lt1 Caprice Wagon(5.7) 2.56Gears
1994 - Lt1 Caprice Wagon Tow Package(5.7) 2.93Gears
1994 - Lt1 Caprice 9c1(5.7) 3.08Gears
1994 - Lt1 Caprice B4U Tow Package(5.7) 2.93Gears
1994 - Lt1 Impala Ss(5.7) 3.08Gears
1995 - L99 Caprice(4.3) 2.93Gears (revised from the early 2.73)
1995 - L99 Caprice 9c1(4.3) 3.23Gears
1995 - Lt1 Caprice Wagon(5.7) 2.56Gears
1995 - Lt1 Caprice Wagon Tow Package(5.7) 2.93Gears
1995 - Lt1 Caprice (c1(5.7) 3.08Gears
1995 - Lt1 Caprice B4U Tow Package(5.7) 2.93Gears
1995 - Lt1 Impala Ss(5.7) 3.08Gears
1996 - L99 Caprice(4.3) 2.93Gears (Revised from the Early 2.73)
1996 - L99 Caprice 9c1(4.3) 3.23Gears
1996 - Lt1 Caprice Wagon(5.7) 2.56Gears
1996 - Lt1 Caprice Wagon Tow Package(5.7) 2.93Gears
1996 - Lt1 Caprice 9c1(5.7) 3.08Gears
1996 - Lt1 Caprice B4U Tow Package(5.7) 2.93Gears
1996 - Lt1 Impala Ss(5.7) 3.08Gears
So if u want some good cheap gears find any one of these vehicles like 1991-1993 9c1(5.7) for the 3.42s or a 1994-1996 9c1(4.3) for the 3.23 s
fullname is offline
post #2 of 32 (permalink) Old 09-05-2010, 06:14 PM
BBODYLT1's Avatar
Send a message via AIM to BBODYLT1
Don't for get the 92 LTZ with the L03 had 3.23 gears.
99 Regal GS
HDI cold air|Gen-V Supercharger|3.5 Pulley|N* TB|LQ4 MAF|Drilled 180 t-stat|AL104 plugs|PJR wires|Alt rewire|9c1 Trans cooler|3.29 gears|TOG headers no cat no res|GTP dual exhuast|GTP trans mount|Flipped M/M's|Monte braces|Rear strut tower bar|GMPP Front-rear sway bars|GMPP trailing arms|9c1 struts|C-5 Corvette brakes|GTP HUD|05 GTP seats|Custom tuned.
BBODYLT1 is offline
post #3 of 32 (permalink) Old 09-05-2010, 07:49 PM
wytltng's Avatar
My 91 had the posi & 3.08's. Would it be considered an LTZ even though it did not have leather & digital dash, but otherwise loaded to the hilt?
wytltng is offline
post #4 of 32 (permalink) Old 09-05-2010, 07:59 PM
I believe the wagons came with 3.23s in the tow package as well.
Fred Kiehl is online now
post #5 of 32 (permalink) Old 09-05-2010, 08:07 PM
BBODYLT1's Avatar
No, the LTZ's also got the FE3 springs, 235 tires and a few other things, its been a while since my LTZ so I don't remember exactly the options it had. But it had every option but leather and a sunroof, not to get off the topic though.
99 Regal GS
BBODYLT1 is offline
post #6 of 32 (permalink) Old 09-06-2010, 05:55 AM
wytltng's Avatar
Gonna check my option codes or build sheet today.
wytltng is offline
post #7 of 32 (permalink) Old 09-06-2010, 11:11 AM
Sophomore Member
Hey fullname, add the axle housing size, carrier size an the three-digit RPO code to your list and you'll get a sticky!
sherlock9c1 is offline
post #8 of 32 (permalink) Old 09-07-2010, 07:00 AM Thread Starter
fullname's Avatar
hummmmmmmmmmmmm.. lets see
1)
"1994 - L99 Caprice Wagon(4.3) 2.93Gears" ... Good luck finding this ONE ... IT is extremely rare
2)
Per the ImpalaSS FAQ and some factory documentation, the standard axle ratio for all L99 4.3L Caprices is 2.73, not 2.93. More importantly, all 2.73 B-bodies used a smaller, weaker axle housing.
3)
If you want some good cheap gears, and are lucky enough to find these ...
1993 L05 Cadillac Fleetwood V4P Tow Package 3.73
1994-1996 LT1 Cadillac Fleetwood V4P Tow Package 3.42
the 2.73Gears only came on the 1994 Caprice Civilian L99(4.3) and was later changed to 2.93Gears for the 1995-1996 caprice Civilian L99(4.3) Models
NEW FOR 1995:
* Impala SS model was available interim '94
* Caprice Classic LS model discontinued
* Bosch ABS V (TM) anti-lock brake system
* Revised exterior appearance w/new foldaway, outside rearview
mirrors and a new quarter panel, and quarter window treatment
(similar to Impala SS)
* Enhanced family of radios
* 2.93 axle ratio standard with 4.3L V8 engine (replacing 2.73
axle ratio)
* Cinching safety belts replace "free-falling" design (rear
seat)
http://www.caminokid.com/1995_chevrolet_caprice.htm
fullname is offline
post #9 of 32 (permalink) Old 09-07-2010, 05:24 PM
Originally Posted by sherlock9c1 View Post
Hey fullname, add the axle housing size, carrier size and the three-digit RPO code to your list and you'll get a sticky!
1)
2.56 ... 2.93 ... 3.08 ... 3.23 ... 3.42 for 94-96 Cadillac Fleetwoods with V4P Tow Pack ... and 3.73 for 93 Cadillac Fleetwoods with V4P Tow Pack
all used the 8.5" axle housing.
Only 2.73 used the 7.625" axle.
2)
2.93 ... 3.08 ... 3.23 ... 3.42 ... 3.73
all used the Series 3 carrier.
Only 2.56 used the Series 2 carrier.
1g1bl82p7rr127841
Rest In Pieces, In Peace
Marky Dissod is offline
post #10 of 32 (permalink) Old 09-07-2010, 05:46 PM
KLASS1C's Avatar
my trunk has a gw9 code which i believe is 2.93's...
KLASS1C is offline
