trans pan bolt torque - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 04-08-2011, 01:09 AM Thread Starter
BareProductions's Avatar
Send a message via AIM to BareProductions
Dumb question: left my shop manual elsewhere...I forget the torque for the trans pan bolts...anyone know it?
Thanks!
95 Caprice Wagon: All the basic mods, Tri-Y headers, SpinTech Exhaust, 52MM TB, Bryan H Tune, Rustic control arms, AirLift Bags.
95 9C1: LE218/224 .571/.566, "561" alum heads, 1.6 RR, beehives, 54MM TB, ported intake, 2.5 catback, Hooker Aero Chambers
73 Nova: Yellow hole where I throw the rest of my $$$
83 Wife: Stock
BareProductions is offline
post #2 of 4 (permalink) Old 04-08-2011, 08:58 AM
Navy Lifer's Avatar
12 lb-ft
There is a note (Fig 10 on pg 7A-15 of my 96 FSM) that shows 2 conditions for the pan bolts, which have a conical (cupped) washer under the head. If the conical washer is collapsed and pushed up flush to the underside of the bolt head, it should be replaced.
If you find all of the bolts are out of spec, the pan uses 16 of them. Also (if using a used stock pan) check the pan rails to make sure they are straight. If the pan bolts were over-tightened and collapsed the conical washers, the pan could have been deformed as well, which would affect the overall gasket clamping pressure when the bolts are installed to proper torque spec.
The bolt PN is 24226008, which has been changed to 24231519, sold as a 5-pack.
Bill Harper
ISSCA #127
inov8r@windstream.net
Navy Lifer is offline
post #3 of 4 (permalink) Old 04-08-2011, 09:07 AM
Sophomore Member
I torque mine to 9 ft lbs.
sherlock9c1 is offline
post #4 of 4 (permalink) Old 04-08-2011, 09:32 AM
juniorwatson's Avatar
Typically what I use for valve covers, oil pans, transmission pans...etc is to use a 1/4" drive ratchet, socket & extension.
It only requires a small amount of torque and using the smaller drive really help prevent over torquing.
juniorwatson is offline
